SolaraGuy.com • View topic - Installing Navi
Installing Navi
Installing Navi
Postby kingkakyle » Thu Jan 10, 2008 12:32 am
So im gonna try to install my navi and junk tomorrow
does anyone have any tips for me?
also which wire do i have to ground so i can use the DVD movie feature while driving (its for passengers not me.....mostly)
eclipse avn5510
Postby Jackass-Jeff » Thu Jan 10, 2008 8:21 am
ground the parking brake wire.
1GR-FE ftw!
Jackass-Jeff
Postby Sebas007 » Thu Jan 10, 2008 9:13 am
Which trim will you use ?? American International or Toyota EOM navigation trim ?
Do you have JBL amp ?
I suggest you to install the GPS antenna right under the 3 display screen...GPS can go thru glass and plastic but not steel.
Postby DrLove » Thu Jan 10, 2008 11:44 am
The "parking" wire is "salmon pink" (almost baby pink) on my Nakamichi. I guess it's the universal color for the parking wire.
I've put it to the ground also, it's illegal I guess :roll: but I like to play videoclips sometimes on the road and my girlfriend watch movies that I already saw in the car when we travel. I can turn the screen so cops will maybe more tolerate it if they catch me. :D
Mazda 6 2010 6 speed black GS
DrLove
Postby Sebas007 » Thu Jan 10, 2008 12:24 pm
The wire on my Kenwood wasn't salmon...was green or yellow...bottom line refers to your installation manual...but the idea remains the same, ground the wire.
Postby [SMAN] » Thu Jan 10, 2008 12:31 pm
Yeah kenwood, parking wire is green, and backup senser wire is pink.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Astro » Thu Jan 10, 2008 4:27 pm
That's cool, I just installed the same navi! Very easy install! Just ground the parking brake wire like others said before. On my gen 1, I took out the DRL sensor on the passenger side of the dash and installed my antenna there, works perfect. I also installed the Eclipse iPod adapter and Parrot bluetooth :D
Postby kingkakyle » Thu Jan 10, 2008 4:38 pm
im having a hard time takeing out the a/c vents and the clock lol
i think im going to die
but yea...i have the basic setup so no amp bypassing and stuff
this is my first time doing a radio install
Postby Gangis » Thu Jan 10, 2008 4:41 pm
kingkakyle wrote:im having a hard time takeing out the a/c vents and the clock lol
Easy to do! Just pull out the ashtray on the bottom then tug on the frame as hard as you're comfortable with. Then it should pop out and all you have to do is unplug the wires on the back. I've done it at least a dozen times.
Gangis
Postby Sebas007 » Thu Jan 10, 2008 4:47 pm
Kyle !! Sorry I forget to tell you how to remove those parts.
The clock...put your thumbs inside 2 of the 3 display screen and pull it. No need of any tool. The A/C...you need to remove the trim from the middle of the car...you know the lid...just pull up and it will pop out....then you'll have access to the 4 main bolts !
Postby Astro » Thu Jan 10, 2008 5:10 pm
I sent you an email with instructions on how to remove the radio trim. It's actually part of a file for XM installation.
Postby kingkakyle » Fri Jan 11, 2008 2:42 pm
sebas...that worked perfectly!! took like 5 seconds!!
and thanks for the email astro helped a lot
now im stuck at another part....alsmost done but i cant find the reverse wire in the front....i dont want to have to run it to the rear taillight....
can anyone help? i tried looking at fuses and haynse manual but im lost
and is the speed wire really necessary?
Postby Astro » Fri Jan 11, 2008 6:42 pm
Yes, in most cases the speed (or VSS) wire is necessary to calibrate your speed. This is so it'll now how fast to move your position marker on the map.
Postby kingkakyle » Fri Jan 11, 2008 7:33 pm
so its almost done but the audio for CDs wont work
the nav audio works, so i can hear directions like turn right at blahblah
but the volume light blinks at 40
any idea are appreciated
what color are the speed and reverse wires?
is the reverse red/black?
Postby Astro » Sat Jan 12, 2008 8:55 am
kingkakyle wrote:so its almost done but the audio for CDs wont work
That's strange, usually when the light blinks, the volume is being muted. It only does that for me when I use my bluetooth phone. Did you hook up the (pink) mute wire? I did, but I believe that's only if you got bluetooth. Make sure if you're not using it, that you tape up the end to keep it from getting any signal. Other than that, I can't think of anything right now.
On the gen1, the speed (VSS) is a violet/white wire coming out of the ECM. It should be the same for you.
The reverse should be a red/black coming out of the junction connector under the glove, left of the ECM. On my diagram, it shows 3 connectors lined up in a row horizontally, with what looks like 3 more under them. The guide shows it pointing to the middle connector on the bottom row. I'm not sure, but it looks like it that could be it. Remember, I hooked mine up at the light.
Return to A/V/N Gen 2 and 2.5
