SolaraGuy.com • View topic - Aftermarket HU
Aftermarket HU
Aftermarket HU
Postby Donnie » Mon Feb 18, 2008 2:45 pm
OK, so I picked up an after market sterio. I got the harness kit that they said I needed. Of course it isn't. "Custom means it don't fit"
Everywhere I looked today had the same one, so no luck. So I've already got my dash torn apart at my shop, no big deal but still. So after I put my dash back together I go online and find the one I need, only problem is this place dosen't give a tech support number to call. What I need to know now, and this is just to keep me from having to pull the stock unit out again until I install the new HU, does my unit have the 15 Pin or 20 Pin jack? It's the unit that came stock with JBL speakers and I don't have the CD changer, just the single load. It's a 2000
Any help?
Donnie
Postby RichD978 » Mon Feb 18, 2008 2:56 pm
you either need to bypass the fact. amp or get the amplified harness i believe its 70-8112. Double check on metraonline.com circuitcity carrys them
RichD978
Postby Ruski » Mon Feb 18, 2008 3:15 pm
YOu need to bypass the Fact amp. its located by the glove box , trace the two wires that go to stock Hu back and you will see the other plug that you will need to use
Ahtermarket HU
Postby Donnie » Mon Feb 18, 2008 6:10 pm
Circuit City has the Amp'ed harness. I'll pick it up tomorrow and let you know how it works out. Thanks guys.
Donnie
Ahtermarket HU
Postby Donnie » Mon Feb 18, 2008 6:12 pm
Circuit City has the Amp'ed harness. I'll pick it up tomorrow and let you know how it works out. Thanks guys. Also I was told that in order to get stuff like this you have to order it for a Lexus since that's what a Solara actually is as far as this goes. Is that true?
Donnie
Return to A/V/N Gen 2 and 2.5
