SolaraGuy.com • View topic - display button/function lost when i installed my HU...
Postby scis30 » Mon Mar 10, 2008 5:08 pm
so i put my stereo in today and my "display" shows but when i push the button nothing happens. I did a search and found something about grounding the yellow and gray wires so i looked and couldn't find them. I didnt see the 3 wire harness the other post said to look for.
I had a 2007 with the 6 disc JBL and bluetooth, maybe someone knows where the wires i need to ground are on this setup.
SOLARAGUY PART 2
i'm baaack
scis30
Postby dvdchris45 » Mon Mar 10, 2008 5:14 pm
lol wtf, i thought you sold your car for a tc?
anyways, the harness IS there regardless of the 6 disc setup from the 04-06. 07 i can't vouch for.... mine was hiding behind the ignition. it's basically the ONLY 3 wire harness that has yellow and stripes which you ground. it took me 3 separate attempts to find it cuz i kept giving up but im sure your would beno different
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby scis30 » Mon Mar 10, 2008 5:23 pm
dvdchris45 wrote:lol wtf, i thought you sold your car for a tc?
yeaa i did trade it in. but after an ice storm a huge chunk of ice fell off of a van and landed on my tC, so I ended up getting another solara. (should have never traded the first one in ) :roll: but sh!t happens.
but yea i'll take it apart and look back there again, I looked but not really on the side of the ignition, i expected to be sitting here and staring me in the face.
thanks man
SOLARAGUY PART 2
i'm baaack
scis30
Postby scis30 » Tue Mar 11, 2008 8:33 am
ok so i took it apart again and saw nothing, the only wires coming from the ignition side plug into the HVAC controls.
SOLARAGUY PART 2
i'm baaack
scis30
Postby [SMAN] » Tue Mar 11, 2008 8:53 am
scis30 wrote:ok so i took it apart again and saw nothing, the only wires coming from the ignition side plug into the HVAC controls.
Ok, see the two plugs in the back (the white and the blue) one of those only has 3 wires in it, and it shouldn't be hooked up to anything currently so it should jsut be dangling there.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Down2TheC » Tue Mar 11, 2008 10:18 am
Search a bit. That's a common ground issue that can be fixed with a jumper if I recall.
Down2TheC
Postby scis30 » Tue Mar 11, 2008 5:05 pm
this is the back of my HU, 07 JBL with blue tooth, i cant find the plug that went in the middle connector on the top row (i dont even remember if there was there but i assume there was))
and this is what i saw when i took apart the dash.
the only things that were unplugged and didnt have a "home" were the two that were connected to the JBL amp...they're pulled upfront and out of the picture...the two that are on the front left go to the HVAC. I looked under/behind the steering wheel part of dash and saw nothing that may have retracted back there and nothing that was unplugged.
I dont know.
SOLARAGUY PART 2
i'm baaack
scis30
Postby boaclub923 » Wed Mar 12, 2008 3:29 pm
there is a white flat plug with like 20 pins or something, but there is only 2 or 3 wires on it.
that wire is used to control steering wheel.
u have to ground one of the wire on that plug
boaclub923
Postby scis30 » Wed Mar 12, 2008 6:28 pm
boaclub923 wrote:there is a white flat plug with like 20 pins or something, but there is only 2 or 3 wires on it.
i been looking for that and dash has been apart 4 times in 2 days, i dont know where the hell it is its so frustrating :evil:
SOLARAGUY PART 2
i'm baaack
scis30
Postby boaclub923 » Sat Mar 15, 2008 2:44 pm
if i didn't remember wrong, it should be the one which plug here.
http://www.geocities.com/boaclub923/photo-5.jpg
if this one isn't the A/C plug, then definatly is this one.
http://www.geocities.com/boaclub923/photo1.jpg
i'm ganan remove my dask apart for blue interior light upgrade very soon.
if u need the exact wire color, i can find it out for u
but i don't think i have time to do it b4 incoming thursday
since i get lots of final coming up.
boaclub923
Postby scis30 » Sun Mar 16, 2008 12:00 pm
ok thanks a lot, i'll probably go in looking for it next weekend, i'm pretty sure that 2nd pic is an AC plug tho
SOLARAGUY PART 2
i'm baaack
scis30
Return to A/V/N Gen 2 and 2.5
