SolaraGuy.com • View topic - 6.75" door speakers installed
Postby TLMNICK » Sat Aug 16, 2008 3:56 pm
Thats a huge spacer place man....did the door panel fit over that ok?
TLMNICK
Postby lvmiltenberger » Sat Aug 16, 2008 4:50 pm
I would like to see how this one turned out, looks nice.
New car blue 90 Nissan 300zx 2+2 5spd
R.I.P White 99 v6 5spd
Cherry bomb muffler so i can hear it :)
lvmiltenberger
Postby mcinque103 » Sat Aug 16, 2008 4:50 pm
it fit with no problem. i used 0.75 inch mdf. the reason i used such a thick piece is because i was origionally going to use the set of kenwood 6x9's that i have. after cutting a bracket for the 6x9's i found that they were still too deep and hit the window when it was down.
mcinque103
Postby gnegroni » Sat Aug 16, 2008 5:29 pm
That is a very sweet looking spacer and setup. :sweet:
gnegroni
Front door speaker wiring
Postby Will1111 » Tue Sep 16, 2008 7:11 am
Did you use the stock speaker wiring or pull new ones through the boot? I will be changing out my front speakers this weekend and was curious how you went about wiring.
Will1111
Postby Ruski » Fri Sep 26, 2008 2:56 pm
the wiring probably needs to be cut, Does anyone know which is positive is it the Pink wire ?
Postby Ruski » Fri Sep 26, 2008 5:33 pm
Nvm i got it . the pink is positive, the purple is negative
Return to A/V/N Gen 2 and 2.5
