SolaraGuy.com • View topic - backup camera wiring ?
Postby PearlSLE » Sun Sep 28, 2008 6:51 pm
Hello , I have a 2006 with stock DVD navi and would like to install a backup camera. What type of wiring is required ? Thanks. :)
PearlSLE
Postby TLMNICK » Sun Sep 28, 2008 8:07 pm
Assuming that a rear backup camera is even an option on that factory unit, It is a matter of finding a reverse signal (a +12V source when the car is in reverse). This can easily be found at either one of the reverse lights at the rear of the car.
That wire will need to be run to both the camera, as well as the head unit. You'll also be running a single RCA from the camera up to the head unit which will carry the video signal.
Its really not a comlicated process so long as your head unit is "rear camera ready"
TLMNICK
Postby linmk2 » Sun Sep 28, 2008 10:47 pm
About a year and half ago I installed an Eclipse BEC105 camera to my factory nav system. It was very easy to do. The wire runs from the camera to the rear of the radio. You simply plug the end into the radio and that's it. Nothing else to do. A very simple and worthwhile upgrade.
Howard
linmk2
Postby dvdchris45 » Sun Sep 28, 2008 11:03 pm
linmk2 wrote:About a year and half ago I installed an Eclipse BEC105 camera to my factory nav system. It was very easy to do. The wire runs from the camera to the rear of the radio. You simply plug the end into the radio and that's it. Nothing else to do. A very simple and worthwhile upgrade.
yup. the end. lol
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby PearlSLE » Tue Sep 30, 2008 4:16 pm
Great guys . Thanks . sounds pretty easy. :P
PearlSLE
Return to A/V/N Gen 2 and 2.5
