SolaraGuy.com • View topic - if i add an amp to factory system how careful do i need to B
Postby Joe Cat » Wed Nov 18, 2009 9:50 am
if i add an amp to factory system how careful do i need to BE ABOUT IMPUTS,
i WAS GOING TO GET THE SCHOSHE LINE CONVERTER TO GET THE rca PLUGS- i CALLED MY RADIO STORE AND THEYSAID THATS JUNK AND TRIED TO SELL ME A $600.00 PROCESSOR
wHAT DO YOU GUYS THINK???
aNYONE HAVE GOOD OR BAD RESULTS
MY CAR IS A 2008 JBL SYSTEM, AND i WANT TO ADD A FIVE CHANNEL AMP AND MB QUARTS 6*9'S
Joe Cat
Postby BadAngel » Wed Nov 18, 2009 1:13 pm
Well first of all, the JBL system has a digital amplifier behind the glove box. so you're probably going to want to remove that. Its digital because it takes 4 outputs from the head unit and splits the front speakers into tweeters and mid/lows. So after the amplifier you have 6 speakers to deal with so in removing it you'll have to power 6 speakers either through the amp or get a crossover.
Honestly you probably shouldn't be doing this without also replacing the stock Head Unit because the JBL head unit and amplifier are made to work together and your going to have a difficult time getting the new amp wired up to the Head Unit Properly
I used a Sosche converter way back when I added my Subs, but I really wouldn't recommend this for all of the speakers, because it probably will mess with the sound quality. I noticed a much better sound when i replaced my Head Unit and ran an RCA cable straight to the sub amp instead of using the Sosche thing.
also, caps lock doesn't get your point across any better/faster/clearer than regular capitalization and punctuation. It's "Caps Lock" not "cruise Control" it just going to get you flamed in the future and Makes a bad impression of yourself.
Anyway, good luck with your audio endeavors!
BadAngel
Postby Joe Cat » Wed Nov 18, 2009 1:39 pm
Thanks and gotcha
Joe Cat
Postby Black Bob » Thu Nov 19, 2009 9:08 am
Agreed, your sound would be so much awesom-er-erer if you replaced the headunit and amp (AND speakers). While the stock JBL is good, making it good-er by adding subwoofers and amp with just line-outs from the stock headunit is gonna cause you major migraines. Take a trip through the thread archives and you'll realize the stock JBL setup doesn't liked to be added to, piggybacked or anyway altered. Plus the little fact that the amp itself is designed to shut down lickety split if it senses the slightest change in electrical current. If you're low on cash I would just change out the speakers first with some good brand name aftermarkets, you WILL notice a difference. Once you get that "Crisp addiction" then you can change out the headunit for one that allows everything but the kitchen sink to be added to it.
Black Bob
Re: if i add an amp to factory system how careful do i need
Postby PhreakdOut » Thu Nov 19, 2009 9:58 am
Joe Cat wrote:if i add an amp to factory system how careful do i need to BE ABOUT IMPUTS,
Joe, look at the screen as you type! (Not the keyboard) Your left pinky finger hit the CAPS LOCK button in the first sentence. :P
Postby crispone » Thu Nov 19, 2009 11:41 am
^^^ fUnNy!!
http://www.solaraguy.com/viewtopic.php?t=32084
oKaY... SO i kNOw thAT I SAid it bEfORe... BuT preTTy mUcH ALL of YoUr QUEstions so FaR are in that thread! (Been there, done that... INCLUDING the Scoche converter... which = JUNK!)
You can really learn a LOT from a few minutes of reading in the audio section! LOTS of others with similar experimentation and ultimately, an opportunity to learn from OUR mistakes and "trial-by-error" experiences. :wink:
^^^ EVEN tried the Scoche box on PAGE TWO already... but if you read on... you'll see where THAT idea went!
G/L! :-?
Postby GzNutz » Thu Nov 19, 2009 12:08 pm
Return to A/V/N Gen 2 and 2.5
Users browsing this forum: No registered users and 2 guests
