SolaraGuy.com • View topic - removing navigation unit solara 2005
Postby ihrinca » Tue Feb 01, 2011 10:39 am
how to remove the stereo unit in my 2005 solara sle ?
ihrinca
Re: removing navigation unit solara 2005
Postby GzNutz » Tue Feb 01, 2011 6:05 pm
Pull the clock/vent plastic towards you. If it's too hard to grip you can pry the hazard light button out and pull from there. No screws on that piece, just clips. Unplug the clock and hazard. Then you'll see 2 bolts holding the stereo in. Remove those and pull the stereo out. The ac control will come with it, but can be seperated by unscrewing 3 side screws.
Please search next time.
This was in the top 5 responses for "stereo removal".
http://solaraguy.com/viewtopic.php?f=27&t=45848&hilit=stereo+removal
Postby ihrinca » Wed Feb 02, 2011 8:48 am
GzNutz wrote:Pull the clock/vent plastic towards you. If it's too hard to grip you can pry the hazard light button out and pull from there. No screws on that piece, just clips. Unplug the clock and hazard. Then you'll see 2 bolts holding the stereo in. Remove those and pull the stereo out. The ac control will come with it, but can be seperated by unscrewing 3 side screws.
Thanks a lot! I appreciated!
Next question: My 2005 Solara SLE did not com with a Navigation system. I found one that comes out of a Solara 2005 too, and I wonder if it can be installed and make it work with my Solara. Thanks.
Ioan
ihrinca
Return to A/V/N Gen 2 and 2.5
