SolaraGuy.com • View topic - DIY FREE INSTANT Air Intake Performance Improvement
Postby DocJohn » Sat Mar 26, 2005 2:45 pm
I've found a FAST, EASY (and totally reverseable) way to re-route the vacuum hoses so that you bypass the Vacuum Switch Valve (VSV) and then IAC valve #3 (the "flapper valve") is ALWAYS FULLY OPEN at ALL engine speeds. RESULT: less air flow restriction, decreased throttle lag and some improved low-end performance.
Here's how to DIY, see: http://www.angelfire.com/ky3/gabby/intake_mod.htm
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
Postby michaels artic frost » Sun Mar 27, 2005 10:17 am
Nice work DocJohn. Keep us posted on your long term results.
Updated 06/01/12: Michael T's
Postby Willy7o2 » Sun Mar 27, 2005 1:14 pm
Wow, cool stuff.... I'm gonna give it a shot today...
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Postby Arthur2k4 » Mon Mar 28, 2005 5:37 pm
well i just did this right now and took it out for a quick spin.... and i dunno if i felt much difference if any...what does this all really mean anyways...lol
Arthur2k4
Postby DocJohn » Tue Mar 29, 2005 5:39 am
--1LOKEDOUTSLE-- wrote:How do you know it will not make your CEL Light come on??? And what are the gains 1/2 HP??????
Because I can read a manual and understand how my engine's ECU operates, and because my CEL is STILL not on after over a week of driving and neither is Swiftoy's months after his similiar mod.
Don't know what the hp gain is, but I do know my throttle lag problem is virtually gone now. For what this mod cost ($0) its is well worth it. As I said, untill someone makes a CAI or SRI for our cars, this is the next best thing.
This pic illustrates my point (photo credit: SWIFTOY)...
This is a photo of the inside of the air box. The small opening (labeled "1") is the only air intake source when IAC valve #3 is closed. On the stock set-up the only time IAC valve #3 opens and allows air through the large air intake opening (labeled “2) is when the when the engine speed is more than 3,200 rpm and the opening angle of the throttle valve is more than 30 degrees.
With this mod, the large air intake (“2") is open at all times allowing for at least 4 times more air flow without any delays from the ECU to sense engine speed and throttle position, then trigger VSV #3 to finally open IAC valve #3. Now, how can this mod result in anything but a performance improvement to at least some degree?
DocJohn
Postby jbauer » Thu Mar 31, 2005 6:00 am
Just did mine a few days ago. Took maybe 2 minutes and the lag IS totally gone. Haven't noticed any drop in MPG either.
Nice work DocJohn.
jbauer
Postby Willy7o2 » Thu Mar 31, 2005 9:16 am
What bothers me is," Why did toyota created it in the first place?" There's gotta be a reason for this setup
2004 Solara V6 SLE
Front GFX Lips
Willy7o2
Postby DocJohn » Thu Mar 31, 2005 11:11 am
Willy7o2 wrote:What bothers me is," Why did toyota created it in the first place?" There's gotta be a reason for this setup
Here's my take on this... This is one of those situations where something works better in theory than in practice. According to the manual, this system reportedly, "reduces intake noise and increases engine power at low to high engine speeds".
Well, as some of us have now seen, it just doesn't really work this way on the street. The system does decrease intake noise, but actually adds to the throttle lag problem (which some have said is mainly due to ECU programming issues) by causing an unnecessary and undesirable delay in available airflow to the engine when required for increased RPM’s.
DocJohn
Thanks!
Postby mmcdonald » Tue Apr 05, 2005 5:18 am
Thanks DocJohn, that reeeeeally works. I did this last night (took about two minutes) and what a difference! This is much better than driving in manumatic all the time.
Now to remove the white permanent intake filter... :bday:
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
4cyl
Postby someazn » Tue Apr 05, 2005 12:43 pm
does this work for the 4cyl?
someazn
Re: 4cyl
Postby DocJohn » Tue Apr 05, 2005 12:48 pm
someazn wrote:does this work for the 4cyl?
I'm still checking on that, I don't know if the 4 cyl has the same air induction system. Maybe a 4 cyl owner can answer this one if they check under their hood and look to see if they have same intake set-up as seen in my photos.
DocJohn
hey
Postby mmcdonald » Wed Apr 06, 2005 4:43 am
Did the 2.4L have the lag problem?
I am getting about 1mpg better with this bypass, and better power availability. I am not sure if there is an increase in horsepower, but what I do have is right on tap, instead of the lag.
XM Tuner DIY
mmcdonald
Re: hey
Postby DocJohn » Wed Apr 06, 2005 5:43 am
mmcdonald wrote:Did the 2.4L have the lag problem?
I really don't know much about the 4 cyl Gen 2 or if it has a lag problem.
I'm seeing exactly the same performance improvements as you describe here. Its great. Thanks for the update. :D
DocJohn
Done
Postby mmcdonald » Mon Apr 11, 2005 5:25 am
Well DocJohn, I did the vacuum trick, and removed the secondary air filter, and the thing works great. Much better mileage, and the power is right on tap.
There is additional engine noise after removing the seondary air filter, but that is a good thing. Once you are at highway speed, it blends in.
Mileage is up on the highway (averaging 34mpg highway this morning.) In town is great as well. I can't seem to get it below 28mpg, even with horsing around.
This is way cool and easy. :bday:
BTW, on the secondary air filter removal, it does not require a Dremel tool. Just take a thin flat blade screwdriver, slip it in behind the filter element at one of the corners, and ROTATE the screwdriver. Don't use it as a pry bar because that will crush the lip on the filter housing. I should know! Once you have one corner free, you can pull the rest of the filter out. It just comes away easily.
XM Tuner DIY
mmcdonald
Return to Tutorials Gen 2 and 2.5
