SolaraGuy.com • View topic - Easy hard-wire radar detector on gen 2 Solara - Pics added
Postby KansasSolara » Sun Jan 29, 2006 3:14 pm
I just added new pics and a short how to to my web site. I hope someone finds it useful.
I decided to mount the detector up high after reading some of the info on the ValentineOne website, they claim that it helps laser detection. I like because it keeps it out of sight from people.
Anyhow, this is one piece of cake of an install and it will get rid of the ugly wires hanging infront of the nice silver Solara dashboard.
Here is the link:
http://www.cardomain.com/ride/2178340/4
Just place your wire where the red dotted line is and run it to the fuse box, the wire can be slid into the panel grooves with your fingers or a standard screwdriver for the corners. I used the fuse for the lighter to make my conection, this way the radar detector will turn off with the car ignition.
KansasSolara
2006 SLE V6
KansasSolara
CowTown Solara Driver
Postby Yanks0114 » Sun Jan 29, 2006 6:18 pm
Looks great - very clean install
I have the same thing on both of my cars, except i keep it on the other side of the rear-view mirror.
How did you tap into the fuse box?
However, mounting it that high may hinder laser performance. At 500 feet, a laser beam is at most 6 feet wide. Cops are taught to target your front license plate with laser. Since the detector is higher, its farther from the license plate, thus reducing the ability to detect laser (especialy at close range). In reality, this isn't that big of a deal, I still pick up laser on mine, and the concept of "detecting" laser is kinda useless because if you pick up the laser warning, you've basically been targeted.
Postby KansasSolara » Sun Jan 29, 2006 6:45 pm
I used the fuse for the cigarete lighter on my install. It seems to be working well there and it is easy to reach when I need to mute it.
I agree with you in regards to detecting Laser, when you do it is too late, but sometimes it can help if you have someone else in front of you and your detector picks up the beam.
Where I live Ka band is the most popular, but laser technology is becoming more commonplace :(
[/quote]
KansasSolara
2006 SLE V6
KansasSolara
Postby tacti » Sun Jan 29, 2006 6:56 pm
yeah, i have pretty much exact the same set up. i tapped into the cig lighter as well.
have you experience sudden dim on the detector screen? i also have an amp and sub, but it is not big one. but just every once in a while, my detector dim for a second. i'm wondering if there's any voltage drop or something..
but other wise, it's working good.
tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby KansasSolara » Sun Jan 29, 2006 7:00 pm
I have not noticed any dimming. Do you have a capacitor for you sub amp? I had that problem in my Gen1, even the car lights would dim when the amp hit a low note, the cap fixed it right away.
KansasSolara
2006 SLE V6
KansasSolara
Gen 2 hardwire radar/laser detector tutorial
Postby michaels artic frost » Mon Jan 30, 2006 6:36 am
Nice write up bro and I'm sure others will appreciate the pics to go along with it.
-M 8)
Updated 06/01/12: Michael T's
Postby stockae92 » Mon Jan 30, 2006 1:49 pm
i have a 8500 as well
the rear sensor is on the top of the unit, so if you mount it too high, it may be blocked from a clean rear view
also note on lazer, if YOU got zapped by lazer and YOU were speeding, you simply should start pulling over
the bad news is that the chances of a ticket is high. since lazer is so narrow and directional, there isn't much reflection off other cars for you pickup.
the good news is that you have time to prepare to hide whatever you need to hide before the cop show up :D
at the same time, lazer can only be deployed in a stationary vehicle.
so far, i only know 1 lazer hot spot on local street, and most freeway cops are using Ka band radar (here in socal)
2006 Solara SLE V6
stockae92
Postby KansasSolara » Mon Jan 30, 2006 6:38 pm
Thanks Mike, I added the images to the tutorial.
Ltr,
KansasSolara
2006 SLE V6
KansasSolara
Radar Detector
Postby GaryPSU » Wed Jun 21, 2006 1:47 pm
Any ideas on how to hide the wire on a convertible?
GaryPSU
Postby KansasSolara » Wed Jun 21, 2006 4:02 pm
If you munt the detector lower on the windshield and route the cable through the front edge of the dashdoard then down the side of the dash and down into the fuse box it will work. I had mine like that for a while, the downside is that the detector will be on plain sight from outside the car.
maybe somebody else has other ideas...
In any case, good luck...
KansasSolara
2006 SLE V6
KansasSolara
Postby Biggi_e » Wed Jun 21, 2006 7:23 pm
i wonder how other hooked theirs u but when i hard wired mine, i hooked it up to the ignition so every time i start up it turns on automatically
Hidden Radar connection
Postby GaryPSU » Thu Jun 22, 2006 4:31 am
The 12V outlet that I'm using goes off with the key as well. I'm looking for an idea for a cosmetic improvement.
GaryPSU
Postby gone » Thu Jun 22, 2006 6:54 am
does that abstruct your view at all ?
gone
Postby KansasSolara » Sat Jun 24, 2006 9:26 am
06toyo chick wrote:does that abstruct your view at all ?
No it does't block the view, it's fairly high up on the windshield, I only notice it when it lights up and beeps.
Just a couple of nights ago it saved me from a speed trap that a cop had set at the bottom of a hill - he was using Ka band and the detector spotted him about 1/4 mile away.
KansasSolara
2006 SLE V6
KansasSolara
Postby woa_its_j3ff » Sat Jun 24, 2006 10:02 am
would this setup work for gen 1s?
Return to Tutorials Gen 2 and 2.5
