SolaraGuy.com • View topic - DIY: cabin air filter
Postby Biggi_e » Thu Jun 01, 2006 9:26 am
-open your glove box
-you will see a little hinge on the right with a screw in it
-unscrew it and take apart the hinge
-then press both sides of the glove department on the black plastic inward
-that will release the glove department and just lay it on the floor
-then if look you will see a white box, move out the wires from it while trying to pull it out.
-then take the filter out and replace with the new
-after that follow the arrow on the box to make sure it is going inside upright.
-after that just attach the glove box and screw the hinge back together
-and thats it
hopefully this may help, i will take pictures when i have a chance.
Postby NotDads » Thu Jun 29, 2006 9:16 am
How often does this need to be done?
NotDads
Postby Biggi_e » Thu Jun 29, 2006 9:20 am
for me i'd do it ever 10,000 miles or so maybe? not sure the recommendation but mine was filthy!
Postby Sap Z » Thu Jun 29, 2006 10:13 am
hey it is the same on gen 1? can someone verify? also where did u get the cabin filter from?
SapZ
V6 SE DWP
Sap Z
Postby Solarafreek » Thu Jun 29, 2006 10:17 am
I dont think gen 1 has one.
Solarafreek
Postby Down2TheC » Thu Jun 29, 2006 9:02 pm
The Gen 2 crowd has come to the realization that Toyo is raping us for the filters and that it's easier, cheaper, and probably better to just chop up a 3M home filter to size.
As far as frequency, I'm doing mine by season. I change it in the fall after the dusty summer and before getting into the winter season where I'm running in a closed up car. If you use your A/C alot then I'd do it in the Spring instead. poor air flow causes bad a/c.
Down2TheC
Postby PXLpainter » Thu Jun 29, 2006 10:53 pm
When I want to clean out the air in my cabin I push the little button on the left side of the dash that says "Open" :D
Postby Down2TheC » Fri Jun 30, 2006 10:35 am
Remind me to teach you about a thing we have here in Chicago... it's called "Winter". It's kind of like when it gets down to 50 in CA... 'cept different.
Down2TheC
Postby Sap Z » Fri Jun 30, 2006 11:41 am
^^^ hey r u planning on making a nice CD compilation for this yrs elmhurst event !!
i still have a smile when i listen to the first track where someone u made it say - Solaraaaaaaaaa
SapZ
V6 SE DWP
Sap Z
Postby Biggi_e » Fri Jun 30, 2006 1:03 pm
even though i changed mine the day i wrote this DIY mine still smells every once in a while but i still dont know what it is but what Down2thec said about changing during seasons wise might be a good idea.
sapz-your avatar buddy... :o :o :o :D
Postby Down2TheC » Sat Jul 01, 2006 12:21 pm
Sap Z wrote:^^^ hey r u planning on making a nice CD compilation for this yrs elmhurst event !!
8)
Then I guess I should start scouting songs and taking requests.
(and that was me with the pitched dropped and an echo.)
Down2TheC
Re: DIY: cabin air filter
Postby yanges » Sun Sep 24, 2006 9:36 pm
Biggi_e wrote:-open your glove box
-and thats it
i was checking my cabin air filter to see how dirty it was and when i put it back together, the glove compartment door now drops like a rock when i open it??
before it had something that lowered the glove compartment door slowly...
can someone tell me what i did wrong?
thanks!!
yanges
2004 Arctic Frost Pearl Solara SE
yanges
Postby XEusioN » Wed Sep 27, 2006 11:57 am
You probably had something stuck in there, mine has dropped like a rock since day one :)
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby Down2TheC » Fri Sep 29, 2006 12:42 pm
Make sure you re-attached the strut on the right side. One screw. If that's on then you're back to OEM.
Down2TheC
Postby RDKamikaze » Sat Sep 30, 2006 1:19 am
Biggi_e wrote:even though i changed mine the day i wrote this DIY mine still smells every once in a while but i still dont know what it is but what Down2thec said about changing during seasons wise might be a good idea.
Did you piss anybody off recently? They could have stuck a dead fish or an open can of tuna under your seat. Other popular suggestions is that you eat in your car and leave the bags in too long, you/others fart a lot, and you drive with the vent open by the cow farms. Whichever applies to you most is probably the culprit. :) .
RDKamikaze
Return to Tutorials Gen 2 and 2.5
