SolaraGuy.com • View topic - 2007 LED Taillight Conversion
Postby ---CAMRAZY--- » Mon Oct 16, 2006 10:52 pm
PM me if you have any questions....
Postby MikeATL » Tue Oct 17, 2006 7:47 am
PICS (of the install) Please!!!!
MikeATL
Postby mluu510 » Tue Oct 17, 2006 7:25 pm
oh wow, thanks guy! i live in oakland. so whoever is closes can help me out, i would really appreciate it!
mluu510
What about Joizy?
Postby liltimmy1313 » Mon Jan 19, 2009 9:33 am
Hey, when i install these 2.5's, the turn signals (reverse lights after conversion) will be amber color, so i am gonna wanna change them to reverse light color, right? Can i even do that?
well, lemme put it this way, will i pass NJ inspection with amber colored reverse lights?
oi vey, so many complications.
thanks for tha help e'rybody
2004 Toyota Solara V6 SLE, stock
but not for long :D
http://liltimmy1313.deviantart.com/art/ ... R-97881991
liltimmy1313
Re: What about Joizy?
Postby [SMAN] » Mon Jan 19, 2009 12:34 pm
liltimmy1313 wrote:Hey, when i install these 2.5's, the turn signals (reverse lights after conversion) will be amber color, so i am gonna wanna change them to reverse light color, right? Can i even do that?
Buy yourself a trailer bulb converter and wire(5 wire -> 4 wire) it so your blinkers control the brake lights. Then you can use the original blinkers as backup lights with a proper bulb. Never had a problem with inspection with that setup.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby iinokturnolii » Mon Jan 19, 2009 1:58 pm
slow down and rethink your questions...
-why would you think you would pass with amber reverse lights?
-how hard is it to change them to white?
-why would you not be able to change them to white?
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby liltimmy1313 » Mon Jan 19, 2009 2:23 pm
hahah i didnt think id pass inspection with amber.
it wouldnt be hard but i was just checkinnn
and yea i dont know why i thought you couldnt change the reverse lights.
its been a longggg day.
but not for long :D
liltimmy1313
Postby bivash » Sun Dec 20, 2009 9:23 pm
hey guys.. would i be able to perform this on my 09 corolla xrs? i want my leds to blink when i turn instead of my actual amber turn signals..
bivash
Postby ---CAMRAZY--- » Sat Dec 26, 2009 10:36 am
Yes, it will work on your corolla.
Postby Ruski » Mon Jan 18, 2010 8:48 pm
I need a dummy downed version of this conversion Can anyone has done this conversion provide me with their notes or help or key points
Postby ---CAMRAZY--- » Sun Feb 14, 2010 12:41 am
Alright so both of the converters finally went out... time to buy new ones....
Postby cklinh » Sat Feb 27, 2010 3:36 pm
Just a heads up.
After reading camrazy's last post, and noticing that my left blinker wasn't working, I figured, hey, my converter must have went out too.
So I went to Kragen to pick up a replacement converter... they didn't have the Hopkins 48915, so I got the next closest thing, 48925.
Go on about my business rewiring everything. When I was done, damn thing still wouldn't work.
So I check my fuses, and realized, hey, why are ALL the left side lights not working? Including the front left signal, my signal light on the sideview mirror, the rear blinker, AND the left arrow on the dash.
AHA! Must be the flasher! since there aren't any side specific fuses for the blinker/hazards. I pulled out the LED flasher and replaced it with the OEM that I kept. All the front blinker lights came on, but alas, the rear still did not. I figured the new Hopkins must not be working (either because it's defective, or the wiring is different... but I did check that, and all wires were labeled the same as the old Hopkins)...
I rewired the old Hopkins converter, and we're back in business.
Long story short, if ALL signal lights on one side are not working, it's the flasher.
cklinh
Re:
Postby yamilo2 » Thu Dec 23, 2010 12:35 pm
kingkakyle wrote:$215 shipped
heres the thread
http://www.solaraguy.org/viewtopic.php?t=28260
reggie is an awsome guy, much props to him for helping me out
This thread is no longer good. Does this guy still selling them?
yamilo2
Re: 2007 LED Taillight Conversion
Postby Savoiskiy » Sun Jan 23, 2011 7:30 am
Just made a conversion and here is a photo. I used 5 Ohm resistors because I couldn't find 6 Ohm ones. Blinking speed in fine, but the resistors become very hot after a minute of blinking. Is that OK? I think I should find a relay and remove the resistors, that would be a safe choice.
'05 SE Sport: Front Strut Brace, Rear Sway Bar, Lowering Springs, Axle-Back Exhaust, All TRD
Soon: 18" Work VS-XX Rims, Injen Intake and more goodies!
Savoiskiy
Return to Tutorials Gen 2 and 2.5
