SolaraGuy.com • View topic - Wheel Offset / Rim & Tire Size Calculator
Postby PXLpainter » Thu Oct 12, 2006 6:32 pm
I've posted this before - so forgive for being a repost... but it doesn't pop up when you do a search, so here 'goes again! :) (Maybe the Mods will make this a sticky?)
This is the most thorough visual calculator I've seen yet - with the most information and side-by-side comparisons to your OEM wheels.
http://www.rims-n-tires.com/rt_specs.jsp
Regardless of your vehicle make/model, etc... this will allow you to plug in any size wheel/tire and show you the comparative results, as well as all the tech specs charted out below.
Here's a sample of what it gives you:
I know there's more out there, like the Miata Tire Calculator, but this one is definitely the shiz! :D
Postby that1mexguy » Thu Oct 12, 2006 6:40 pm
It already helped me man, i freaking love it!! again, thanks a bunch!!
that1mexguy
Postby KRIS05VVTi » Tue Apr 28, 2009 7:09 pm
so what is the stock bolt pattern on a 05 solara?
KRIS05VVTi
Postby Titan_X » Wed Apr 29, 2009 11:24 am
KRIS05VVTi wrote:so what is the stock bolt pattern on a 05 solara?
Should be 5x114.3
Titan_X
Return to Tutorials Gen 2 and 2.5
