SolaraGuy.com • View topic - WANTED : Transponder key to fit a 07 SLE
Postby RedrocketGEM » Mon Jul 21, 2008 6:44 pm
:roll: I am looking for a cheap key to use as a spare transponder head only.
The metal shaft is of no interest.
contact: redrocketgem@netscape.net
RedrocketGEM
Postby PearlSLE » Mon Jul 21, 2008 7:41 pm
E bay $ 14.00 to the door. HAVE A SOLARA DAY.
PearlSLE
Postby NeFaRiOuS_SLE » Tue Jul 22, 2008 8:54 am
Welcome to SolaraGuy... Noticed that this is your first post.
Anyway, like PearlSLE said you can find a whole transponder key cheap on eBay, but in order to program said key to your car it DOES need to be cut/copied (but your local locksmith might only be less than $3), especially considering that you might have to turn the key in the ignition several times as part of the programming process.
Postby PearlSLE » Tue Jul 22, 2008 1:17 pm
This is correct. Key was $ 14.00. Cut was $ 5.00 at locksmith. I
picked up the programing procedure at toyotanation.com.
Works great. The dealer wanted $ 90.00 for the key alone.
Good luck.
PearlSLE
Solara ket wanted
Postby RedrocketGEM » Sat Jul 26, 2008 10:33 am
Thanks guys, but knew all that already.
On to Ebay.
Regards
RedrocketGEM
