SolaraGuy.com • View topic - 2002 Camry under dash chirping
Postby jbn19431938 » Thu Jul 22, 2004 5:01 pm
I just bought a 2002 V6 Camry. Occasionally with engine and a/c running i will hear a short whistle or chirp from under the dash. Any idea what this might be?
jbn19431938
Postby michaels artic frost » Thu Jul 22, 2004 5:49 pm
Do you have an aftermarket alarm installed on the car?
Updated 06/01/12: Michael T's
Postby Mole » Thu Jul 29, 2004 3:48 pm
SolTech wrote:no
what's that supposed to mean?
if that sound comes on ONLY when you turn the AC on, its normal since its the clutch working on the pulley for the compressor to start charging the R134a (AC fluid) up.
Postby jbn19431938 » Thu Jul 29, 2004 4:21 pm
TRDMole177 wrote:
SolTech wrote:no
This chirp does not occur at start up, is not a belt slipping sound, etc. It occurs occasionally, erratically, unpredictably, and sounds for all the world like a brief bird chirp.
jbn19431938
Postby Mole » Thu Jul 29, 2004 7:24 pm
so does this sound occur when the AC is on or not?
Postby jbn19431938 » Fri Jul 30, 2004 12:13 pm
TRDMole177 wrote:so does this sound occur when the AC is on or not?
'Spose I should turn off a/c and see if it still occurs. Been hot enuf here this summer that I have always run a/c
jbn19431938
Postby Mole » Sun Aug 01, 2004 12:31 pm
ok, then i am certain that it is the A/C compressor you are hearing clicking on and off.
nothing to be worried about. its normal procedure for the a/c compressor.
Postby MrMikeL » Tue Aug 03, 2004 10:52 am
Might it be the blower motor? I had a similar problem on a '96 Camry Wagon V6. It was intermittent, sounded like a bird under the dash. Had to have the blower motor replaced, and that fixed it.
MrMikeL
Postby jbn19431938 » Tue Aug 03, 2004 2:06 pm
MrMikeL wrote:Might it be the blower motor? I had a similar problem on a '96 Camry Wagon V6. It was intermittent, sounde dlike a bird under the dash. Had to have the blower motor replaced, and that fixed it.
sound has an almost pheumatic quality, as if it is a wind musical instrument
jbn19431938
sound has an almost pheumatic quality, as if it is a wind musical instrument[/quote]
sb pneumatic
jbn19431938
Postby jbn19431938 » Wed Nov 10, 2004 7:20 pm
jbn19431938 wrote:sound has an almost pheumatic quality, as if it is a wind musical instrument
sb pneumatic[/quote]
Ever think that "pheumatic" might also indicate an airy odor? Possibly a fart?
jbn19431938
Return to Toyota Camry
