SolaraGuy.com • View topic - Is the plastic next to your window switches sagging?
Postby NotASolaraYET » Thu Feb 10, 2005 4:53 pm
We have a 99 Camry, adn the part where the vinyl, door padding, (on the side of the armrest) where it meets the window switches, has separated, and is sagging down, leaving a gap between it and the switchplate.
Its no big deal, but it bothers me to look at.. I cant fix it.. The clips that hold it to are broken
Just wanted to know if anyone else is having this problem..
NotASolaraYET
Postby CASTRO » Thu Feb 10, 2005 8:58 pm
*raises hand*
CASTRO
Postby MentatGom » Thu Feb 10, 2005 11:30 pm
99 camry... yeah, on my passenger front door... there is an ever so slight gap.
MentatGom
Postby Jai_Jai_Binks » Fri Feb 11, 2005 9:52 am
strike another gen4 having the same problem! :RAISESHANDS:
I've got carmax to glue it before (under warranty), it a temp fix, but in time, it has sagged again. So i don't think there is a perm cure to this. From being a valet parker, i've only seen this on driverside door panel where people had simulated wood overlays.
Postby gLok » Sun May 15, 2005 8:10 pm
I used a two part epoxy on mine and it worked fairly well. I just removed the entire door panel off of the car, mixed the epoxy, spread it all over the vinyl that separated from the foam and laid a few books on it until it pushed it down. Once it dried, the vinyl stuck much better and closed the gap by a noticable margin.
Id still like to find out of the Japan built Camrys had this problem as well and if not, id like to order a new set as its still not up to my standards.
99 Camry V6 5 speed - built 1mz +++
90 Integra LS 5 speed - daily beater
http://www.legacytuning.com
http://www.grantscustomrigging.com
gLok
Postby trdkamuri51o » Sun May 15, 2005 9:00 pm
hahah damn i got a 97 and i dont have that problem
trdkamuri51o
Postby cam2Xrunner » Wed May 18, 2005 2:02 am
Just a guess but the people with the sagging doors, were your cars built in the U.S.A? And trdkamuri51o I'm thinking your camry was built in Japan?
cam2Xrunner
Postby Jai_Jai_Binks » Wed May 18, 2005 7:46 am
Yes my gen4 was built stateside, dealership fixed the problem (under 36K warranty) back in the day, but the problem came back...
Edit: Has leather!
Postby trdkamuri51o » Wed May 18, 2005 12:52 pm
nope american made. 4t1bg beggining tells me its a us car.... that and i have leather, but my wifes 97 and sisters 97 all dont have it either and they have the velour.
trdkamuri51o
Postby trdcamrygracia » Wed May 25, 2005 11:15 am
my 99 got same problem too :roll:
07 BMW E60 530I JET BLACK
07 BMW E85 Z4 3.0i JET BLACK
trdcamrygracia
Return to Toyota Camry
