SolaraGuy.com • View topic - Car's RMP drops when idling, please help .
Postby TRDMIKE3 » Mon Nov 07, 2005 4:33 pm
When the car idles at a stop light, or at anykind of rest, the RPM drops.
Took it to the dealer and they did their test, they said nothing was wrong
with it. what u guys think?
Just put in brand new battery.
Checked volt when car is not on 12v battery
Checked volt when car is on 13.9v eliminates alternator problem
TRDMIKE3
Postby SolaraBlue » Mon Nov 07, 2005 4:36 pm
i think youll be fine. doesnt sound out of the ordinary. if it was reving high when youre stopped then, id worry.
Postby Turbosolara » Mon Nov 07, 2005 4:42 pm
it is possible that your power brake is ripping out some power from your motor. what is your mileage? what kind maintainace you have done? is it auto? (i thought that is a common problem to all automatic cars? i am not sure since i never had automatic in my life)
Postby TRDMIKE3 » Mon Nov 07, 2005 8:58 pm
car has 30,000 miles and yes it's an auto..... it's my dad's car well
taken care off for 3 years since new.
TRDMIKE3
Postby Yanks0114 » Tue Nov 08, 2005 1:20 am
Probally the Idle Air Controller - search the forum for IAC
Postby Smoothro » Tue Nov 08, 2005 5:12 am
You might have gotten some bad gas (gas with a little water in it). Do the RPM's go down as though it may choke off? I had something simliar to this happen to me b4. IT caused my CEL to come on, and the dealer told me I needed a new PCV valve. I didn't get it then, and after a couple of days the CEL light went off. I just added some fuel system cleaner to the gas.
Smoothro
Postby PhreakdOut » Tue Nov 08, 2005 5:52 am
Yanks0114 wrote:Probally the Idle Air Controller - search the forum for IAC
I would second this opinion.
Postby Yanks0114 » Tue Nov 08, 2005 5:52 pm
Re: Car's RMP drops when idling, please help .
Postby Vampire » Fri Dec 02, 2005 11:27 pm
Gonna sound stupid but have you checked the air filter? i like to go simple first. This can cause low idle if it's filthy. IAC is high on the list of things that can cause this but so can throttle position sensor going bad, a clogged fuel filter and dirty injectors. Good luck and let us know how this turns out.
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby CASTRO » Sat Dec 03, 2005 1:34 am
PCV valve... my gfs i4 Camry died easily at idle what it was like that. Also check the EGR. Hers always got stuck and you actually had to hold the throttle until the engine warmed up a bit to do it on its own.
CASTRO
Postby hskrsolara » Sat Dec 03, 2005 1:46 am
I had the same problem with my pickup and it was the pcv valve also. I'd check that first.
hskrsolara
Return to Toyota Camry
