SolaraGuy.com • View topic - Aluminium airbox for CAI
Postby keithy » Sat Feb 25, 2006 4:59 pm
Have anyone seen/use this before? looks neat.
http://cgi.ebay.com/ebaymotors/98-03-To ... 2062QQrdZ1
but $80 is too much for me for an aluminium box.
keithy
Postby Biggi_e » Sat Feb 25, 2006 5:52 pm
very interesting..would they have anything like this for the gen2 solara?
Postby keithy » Sat Feb 25, 2006 6:09 pm
I have no idea whatsoever. To be certain, you can email them to ask. good luck.
keithy
Postby hskrsolara » Sat Feb 25, 2006 6:16 pm
damn, thats an expensive piece of aluminum.
hskrsolara
Postby keithy » Sat Feb 25, 2006 6:28 pm
hahaha......... agree, agree.
keithy
Postby DatSRBoi » Sat Feb 25, 2006 8:14 pm
Not worth your money. its still under the hood. heat will heat that thing up. And it will turn into an underhood Oven air system :)
Postby ctbuhay » Sun Feb 26, 2006 11:58 am
if you have a v6 then i say you go for one of these. http://www.cardomain.com/item/INJIS2032P?vq_id=none
im gonna be getting the same thing.
ctbuhay
ctbuhay
Postby JavaJoe_2 » Sun Feb 26, 2006 5:10 pm
JavaJoe_2 wrote:Hi, I'm interested in this CAI Airbox.
Do you happen to have a picture of the unit not installed on a car?
Where is the air inlet located.
What size is the air inlet?
Does the unit require a filter, if so what size filter?
Thanks, Joe
davidolan04 wrote:Im sorry I do not have any additional pictures. This itme is designed to work with your current cold air intake and filter by giving it a housing so that it does not soak in water and other things that are harmful for your engine. It works with all brands of cold air intakes as well as your stock intack by replacing the airbox and using your stock filter. Thanks
-Dave
With "his" explanation of "his" product, I would say that it is probably useless. You could probably gain more drilling out the bottom of your stock box and using the money to buy a K&N filter and a six pack of beer. :drinking:
Got Boost?? :sweet:
JavaJoe_2
Return to Toyota Camry
