SolaraGuy.com • View topic - dual exhaust for 2002 v6 camry
Postby ctbuhay » Mon May 01, 2006 6:55 pm
does anyone have any experience with anyone who has done a true dual exhaust using X pipe or H pipe? i am thinking of making that move for my car and was wondering if anyone could help me out. leave me some comments, everything is helpful. thank you in advance.
ctbuhay
Postby jhenty » Mon May 01, 2006 7:39 pm
Im sure you know the only way to go is custom. What I would do is have a custom y-pipe made (except no longer a y but possibly an x) and just run it back from there with 2.5" piping, high flow cats, and a good set of mufflers. Personally I wouldn't convert to "true" dual because it would require two cats if your concerned about emissions. I would custom make a y that flows better and direct that into a single cat converter and split from there back. Maybe you can tell us whether or not this is more for looks or for performance?
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby ctbuhay » Mon May 01, 2006 10:24 pm
its somewhat both.. but more towards looks, but i wanna get as much performance out of it as possible. im not too worried abouth the emissions stuff though.
ctbuhay
Postby DaveMush » Fri May 05, 2006 3:12 pm
2 smaller cats would flow more than one larger cat...
the thing is that you need to have the 3rd o2 sensor in the middle of the x or h in the pipe, it needs to be able to read the result of both banks-worth of exhaust combined.
you need to figure that w/ only 3 cylinders worth of exhaust running through both cats, you will need to size it so they will both light off, but w/o restricting too much. in the v6, the cats are the largest restriction past the stock y-pipe. but then again, the exhaust cams could make huge improvements too...
177Hp/186Tq Stock and OBDII compliant...
Dyno
DaveMush
Postby ctbuhay » Fri May 05, 2006 7:22 pm
cool cool. thanks for the info. really helpful stuff. hopefully soon i'll be able to have all of it done. thanks again for the help.
ctbuhay
Return to Toyota Camry
