SolaraGuy.com • View topic - synthetic oil
synthetic oil
synthetic oil
Postby CamryJas » Fri Feb 07, 2003 3:49 pm
Is it safe to put synthetic oil in a v6 camry auto? I have heard many stories where u want to mix synthetic first with conventional then switch to synthetic and after that you can't switch to conventional again. What is the real deal and if any of u use synthetic do u use mobil?
2000 Camry XLE v6
CamryJas
Postby Yanks0114 » Fri Feb 07, 2003 4:13 pm
Depends on how many miles you have. I don't reccomend if you have over 75k miles, but other than that go for it. I run synthetic and I love it and btw there is no switching procedure, just add it in
Postby krazeee1707 » Fri Feb 07, 2003 5:21 pm
I run synthetic on my 1992 camry v6. I think thats probably why i have 190000 miles on it.
krazeee1707
Postby CamryJas » Fri Feb 07, 2003 9:55 pm
I have 37k miles on it. IT should be ok.
2000 Camry XLE v6
CamryJas
Postby CamryJas » Sat Feb 08, 2003 10:17 am
which synthetic do u use? Mobil 5W-30?
2000 Camry XLE v6
CamryJas
Postby Flipside909 » Tue Feb 11, 2003 4:53 pm
CamryJas wrote:which synthetic do u use? Mobil 5W-30?
5w30 is correct.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby 03RKC » Sat Apr 10, 2004 4:42 am
You can use a syn oil right from day 1. A lot of high line autos and bikes come with syn oil right from the factory.
03RKC
Postby DavPak » Sun Apr 18, 2004 12:55 pm
03RKC wrote:You can use a syn oil right from day 1. A lot of high line autos and bikes come with syn oil right from the factory.
however, the fact remains that toyota does not recommend synthetic oil. doesn't mean i don't use it, but toyota doesn't recommend it.
BTW, please refrain from digging up posts over a year old in order to make a useless comment on them.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby 03RKC » Sun Apr 18, 2004 1:35 pm
[however, the fact remains that toyota does not recommend synthetic oil.]
They don't specifically tell you not to use it either. They just say use an oil that meets or exceeds there recommendations.
03RKC
Postby onefiend » Sun Apr 18, 2004 2:26 pm
I'm passed 50k miles, I think its time for synthetic oil.
onefiend
Return to Toyota Camry
