SolaraGuy.com • View topic - Brake Problem...
Brake Problem...
Brake Problem...
Postby Nodrogkam » Sun May 28, 2006 9:19 pm
Hey i was wondering if someone knew the answer to my problem.
Yeah i wasnt too bright going into this...it was a spur of the moment thing and i know i will be paying for it.
I was rotating my tires and said why not let some old brake fluid out. I unbolted the brake line at each caliper one at a time and pumped the brake pedal once lightly at every time i detatched a brake line. I believe i reattatched properly and tightly but upon restart of my car the brake pedal just goes to the floor. I collected the amount of brake fluid i let out and it wasnt much at all.
Tomorrow morning i'll take off each wheel and double check. Probably just one of the lines are loose...or there is now air in my brake system. Would i need a brake bleed kit for that then?
Thanks for any and all help!! I hope to get my car back into driving condition by the end of tomorrow morning.
1998 Camry XLE V6
My Car Domain
Nodrogkam
Postby camry_101 » Sun May 28, 2006 9:24 pm
you probably got a loose line/air same thing happened with a car we had a few year back
camry_101
Postby Nodrogkam » Sun May 28, 2006 9:29 pm
i hope so...although most signs point to air in the brake system. :-?
Thank you.
1998 Camry XLE V6
My Car Domain
Nodrogkam
Return to Toyota Camry
