SolaraGuy.com • View topic - Dual Exhaust on Camry
Postby JMSinMaryland » Thu Jun 29, 2006 7:47 pm
Has anyone done it? It's a thread on Toyotanation.com and Im thinking about doing it, maybe adding another TRD/Borla muffler. Where to split it? Is there room? Etc. Thanks. ps. bad photochop below
JMSinMaryland
Postby Mole » Fri Jun 30, 2006 3:10 am
not sure on a camry, but i believe Flash did on his gen 1 solara
Postby ---CAMRAZY--- » Fri Jun 30, 2006 6:02 am
Not TRDs but Billy Shae has Duals
Postby mzfe5speed » Wed Oct 25, 2006 2:08 pm
yeah theres room, if you just do a y-pipe at the back to the other muffler. i have seen quite a few camrys w/ dual, but not true duals. i think there is a few threads on TN, not sure exactly where, but just do a search and you should find them.
Go Camry Go!!!
Was Officially BOOSTED!!
(And Loved It!)
http://www.cardomain.com/ride/2488906
mzfe5speed
Postby ASG14 » Fri Oct 27, 2006 9:28 pm
I've looked into to. It CAN be done, but NOT with the same size muffler as stock. The Spare Tire is offset to the left, so there is less room on the left side to fit a muffler. Needs to be a small one.
ASG14
Postby zippy » Sat Oct 28, 2006 10:15 am
Check out 808 Camry’s dual exhaust.
zippy
Postby pwizzle » Thu Nov 09, 2006 11:33 pm
I thought that you lose back pressure if you put a dual exhaust on a car.
pwizzle
Postby ASG14 » Wed Nov 15, 2006 1:17 am
^ Depends on engine and Mods, and if it is desinged correctly. If you have a stock 5SFE, it definatly would just be a waste.
ASG14
Return to Toyota Camry
