SolaraGuy.com • View topic - HELP! - working on my brakes
Postby trd628 » Fri Jan 05, 2007 11:47 pm
replaced my brakes (pads, and rotors) today. did the front and everything was great. went to do the back and gor the new pads on and rotor on and the dang things makes a grinding noise from the e-brake. tried adjusting it how my Hanes manual says and still no luck. after I adjust it no noise but the second I pull the e-brake it grinds again. anyone got any advice. the car is in the garage as we speeak on jack stands so any advice would be VERY HELPFUL!
trd628
Postby Nodrogkam » Fri Jan 19, 2007 11:36 am
hey, when you replaced your rear rotors did you check to see if the brake shoes for the drum (e-brake) needed to be replaced?
(the rear brakes of your camry is a combo of disc for reg braking and drum style for e-brake)
it sounds to me that you have a sticky/stuck rear e-brake drum.
you may have to take off the rear rotors and see if something is stuck/sticky.
1998 Camry XLE V6
My Car Domain
Nodrogkam
Return to Toyota Camry
