SolaraGuy.com • View topic - lug nuts type?
lug nuts type?
lug nuts type?
Postby keithy » Tue Feb 13, 2007 4:30 pm
anybody here knows what is the difference in application between an open end lug nuts and closed end lugs?
Reason I asked was that when I called up a store to purchase a set for my Team Dynamics Monza wheels, the sales person told me that open end was intended for under cap fitment while closed end lugs are for exposed lugs.
Is that true?
keithy
Postby anttarz » Tue Feb 13, 2007 4:33 pm
they use open ended on cars with center cap covering because they are cheaper. They would look dumb if exposed.
anttarz
Postby PXLpainter » Tue Feb 13, 2007 4:35 pm
Usually - it's a cosmetic issue - unless you like the "NASCAR" look on your ride! ;)
Postby keithy » Tue Feb 13, 2007 4:41 pm
Thanks for the quick replies, guys.
so, I'll be fine with closed end lugs even with the center cap on. correct?
keithy
Postby ptballer » Tue Feb 13, 2007 11:27 pm
The center cap may not fit over closed ended lug nuts.
ptballer
Postby keithy » Wed Feb 14, 2007 5:25 am
ptballer, oh... that was why the sales person said that. Initially I thought that he was just being lame and did not want to verify that closed ends wouldn't fit. I kinda like the closed ends more than the open ends, which was why I asked the sales person. But he never explained and kept putting me on hold to speak to another customers(then asked me to call back later).
keithy
Return to Toyota Camry
