SolaraGuy.com • View topic - short ram? or Cut hole
Postby netherland24 » Tue Mar 20, 2007 9:42 pm
alright guys i have been reading and herd that short ram intake is just for the noise... and looks. and by cutting the bottom of the air box it will do the same as for noise haha. nothing more.
is this true?
- its for a gen 4 camry
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby Ruski » Tue Mar 20, 2007 9:50 pm
i pulled my Res out of my fender but still sounds the same, besides you can hear the hissing noise of the intake, thats all i gained from it
Postby netherland24 » Tue Mar 20, 2007 9:51 pm
i could care less for sound.. just want too know if any improvements are made?
00 SS Lara 277hp
netherland24
Postby Ruski » Tue Mar 20, 2007 9:53 pm
Nope none at all dont even bother
Postby ASG14 » Wed Mar 21, 2007 12:40 am
^ Ditto
All I did was remove my wothless resonator in the fender. But plan to make a TRUE CAI (forced air from the bumper opening)
ASG14
Postby onefiend » Fri Mar 23, 2007 6:05 pm
Just get a K&N or TRD drop-in air filter.
2007 Camry SE V6
onefiend
Postby Sebas007 » Fri Mar 23, 2007 6:51 pm
short ram
Postby NRDriver » Fri Mar 23, 2007 7:09 pm
my stock intake came off all the time when i peeled out. thats why i got the short ram. more sturdy
NRDriver
Postby crispone » Fri Mar 23, 2007 7:13 pm
Yeah... bad memories...
^^^ FILTERLESS VELOCITY STACKS :o
If you look CLOSELY, you will see the OPEN VELOCITY STACKS on this bike. After RUNNING with them for a couple thousand miles... I had to repeat an EXPENSIVE engine rebuild... all for a few horses and KILLER intake HONK! (The bike consumed A BUNCH of God's Creation for those handful of "unadulterated" intake miles... but I won't do it again. This thing breathes COMFORTABLY through K&N stacks now... and is actually less "LIGHT-SWITCH" tempermental between ON and OFF throttle transitions.
DON'T run WITHOUT filtered air! It's JUST like pouring SAND into your engine. :-?
Postby DatSRBoi » Fri Mar 23, 2007 7:56 pm
Just keep your stock intake on and remove the resonator and water catch looking box. Not worth spending all that money for like 3-5hp. Rather put that 150bucks plus to gas or a good night out with some friends or even HIDs which does more benefits. I just removed the bottom resonator off my accord. Save me 140 bucks and works just fine if not better then stock.
I went from
To this.
Imagine how less the car has to work and you didnt have to spend any money for a wasted few Hp where youll eventually sell the car anyways.
Postby Edmo83 » Sat Mar 31, 2007 1:47 pm
I just thought i'd add, that i got an INJEN CAI, and i feel the difference. but i had much more torque with the SRI basically without the extension.
One more thing i wanted to mention, ive gotten an extra 2mpg on average this month. not too shabby, lol
one drawback is, my cel comes on every so often. i gotta find out whats causing that.
Ed
Edmo83
Postby Astro » Sat Mar 31, 2007 2:30 pm
If you got the money do the SRI or SRI w/CAI extension. Otherwise, cut the box...
Edmo83 wrote:I just thought i'd add, that i got an INJEN CAI, and i feel the difference. but i had much more torque with the SRI basically without the extension.
Ed
What codes are you getting? It could be that your throttle body and/or the MAF sensor needs cleaning.
Return to Toyota Camry
