SolaraGuy.com • View topic - 19x8 +50 et w/ spacers
Postby trdkamuri51o » Thu Apr 05, 2007 10:50 pm
hrmm so im considering some really high offset wheels so i can run giant hub spacers (or not just kidding)
but seriously what would be the absolute best offset for a 19x8 wheel no rubbing shaved fenders to push it to the outter limits..
im still learning the offset game, but the wheels im ordering (800 a pop) are full out custom specs... so i can get them however i need them
the flares in the front and rear will push the car stance about 1 inch more so im guessing 10mm wont hurt too much
front and rear offsets matter!!! since i wanna push to the outter limits!!!!
trdkamuri51o
Postby **PoshPepper** » Fri Apr 06, 2007 9:05 am
If you want to push to the outer limits you should run a wider wheel than 8...
But to answer your question, a +40 to +35 would be where to start and then add your spacers as needed...
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby Sebas007 » Fri Apr 06, 2007 9:12 am
Smaller offset for a same width rim push the rim to the outside. The offset is calculated from the middle of the wheel. So a 8" width rim is 4" + an offset in millimeters
So a 35mm offset will be closer to the middle (the contact point with the hub) than a 50mm offset will be more outside the middle of the wheel of 15mm so the contact point is further the wheel will go more inside toward the car. You just to imagine it..take a picture in your head of the wheel and how it mounted to the car...you will instantly see how it works.
Again wider rim can gives you or not the result you want. Everything is a question of width AND offset.
Use this tools to figure it out quickly
http://www.1010tires.com/WheelOffsetCalculator.asp
Postby ---CAMRAZY--- » Sat Apr 07, 2007 7:36 am
So you want something like this?
Postby Patrik » Sat Apr 07, 2007 8:35 am
VIP style is sick :)
1999 SE V6 5 speed SOLD
Patrik
Postby ---CAMRAZY--- » Sat Apr 07, 2007 1:10 pm
YUP!!!!!!!!! Wait for mine to come out and play!!!
My little teaser....
We are back on track with the coupe, soon my people... soon.
4" lip in the rear and 2" lip for the front.... LOL
Postby Patrik » Sun Apr 08, 2007 7:31 am
ooooooooooooooooooo :)
this is noice !
reminds me of the wheels my friend had on his 350z
Patrik
Postby trdkamuri51o » Sun Apr 08, 2007 10:41 am
lol milton.. yea something like that... im still debating if i should go balls out though..
go hard or go home???
trdkamuri51o
Postby Toy1mzfe » Sun Apr 08, 2007 11:37 am
Go hard!!!!! You know all cars that run with width ass wheels are sick as fux.
"Wider is better," Who cares if its kinda wider in the back and doesnt do shiz for us fwd cars. It looks sick!!!
Any idea what wheels u plannin to get next?
Postby ---CAMRAZY--- » Sun Apr 08, 2007 12:52 pm
trdkamuri51o wrote:lol milton.. yea something like that... im still debating if i should go balls out though..
LOL, yeah... 9.5 in the rear, 8.5 in the front.... No flares, just stretched tires and lots of / \ Negative camber....
Postby krawzyazn » Sun Apr 08, 2007 2:21 pm
you have 2 sets of rims already and stop buying rims made for an accord or TL
Postby indiglosolara » Thu Apr 26, 2007 10:13 am
If you want a sick fitment for the Camry.. go like what milton said...
19x8.5 front with a +32 or +30 offset with some 225/35 stretched tires...
19x9.5 in the rear with a +30 offset with 235/35 tires.. -3 degree chamber in the rear and you should be set...
If you want wheels that will be the same width all around then do staggered offsets. Since the Camry's rear wheels sit about 10mm more in the rear you can do... 19x8 with a +35 offset front and 19x8 +25 offset in the rear with some 225/35 tires or even 215/35 for the really stretched look will fit.. you might need some negative chamber for the rear but if your fenders are shaved like mine you shouldn't...
My xB will be running a effective +33 offset in the front and +13 offset in the rear once I am done...
but I am running the same width all around...
Last edited by indiglosolara on Thu Apr 26, 2007 10:15 am, edited 1 time in total.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Thu Apr 26, 2007 10:14 am
krawzyazn wrote:you have 2 sets of rims already and stop buying rims made for an accord or TL
LOLZ!!!!!!!!
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ---CAMRAZY--- » Mon Apr 30, 2007 3:56 pm
Here are some more pics to get you to invision your camry...
Postby Biggi_e » Mon Apr 30, 2007 4:44 pm
sick pictures
Return to Toyota Camry
