SolaraGuy.com • View topic - How to remove a factory foglight on a 99 camry
Postby TMMK Toy » Sat Aug 04, 2007 5:20 pm
Well since I had my foglights fubared from the semi tire I'm gonna remove them. The pass. side was easy since it was already hanging out of the housing so I just unclipped it and it came out. The driver side was still in the housing but bent. I removed the top two phillips screws and tried to loosen the bottom adjustment screw all the way but still cant get it to come out of the housing. What else do I got to do or am missing?
TMMK Toy
Postby aleki2424 » Sat Aug 04, 2007 6:50 pm
if you're talking bout the foglight, there's a screw that goes through the side and another that goes through the rear.
the rear of the foglight has a threaded prong sticking out that slots into a hole in the back of the housing.
the side of the fog has a hole where a screw holds it into the housing.
both of them are kinda hidden so you might have to flex a little under the bumper
aleki2424
Postby TMMK Toy » Sun Aug 05, 2007 9:11 am
Thanks man. I'll look for this side screw. Prob. what I'm missing. I found the adjustment screw as stated above but does me no good on taking it out.
TMMK Toy
Return to Toyota Camry
