SolaraGuy.com • View topic - changing door handles
Postby syxx » Sun May 04, 2003 6:39 am
does anyone know if it is possible to change the door handles? i have a 99 camry and it has the regular handles and i want to change it to have the handles from the 2002 camrys. is that possible?
syxx
Postby Jackass-Jeff » Sun May 04, 2003 9:09 am
Anything is possible w/ the money...
The idea would come from the so called "suicide/shaved" handles. But instead, you would have to resize the opening for the handle to fit the 02 handle. The mechanical linkage may give some problems...
1GR-FE ftw!
Jackass-Jeff
Postby Flipside909 » Sun May 04, 2003 9:33 am
It's doable if you can justify the cost for modifying your door and the labor to make it work. In a practical sense, it's not worth it.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby syxx » Sun May 04, 2003 11:33 am
:oops: :( ah well
syxx
Return to Toyota Camry
