SolaraGuy.com • View topic - question on my problem
Postby Jai_Jai_Binks » Thu Nov 08, 2007 6:08 pm
on my 1997 camry....my dual fillament h4's stopped working (both at the same time) fuses are ok..low beams are out, but high beams work? I'm driving in the night time with highs only.
WTF is my problem.......
Postby Midias » Thu Nov 08, 2007 6:34 pm
check fuses with a meter
Postby Mole » Thu Nov 08, 2007 6:59 pm
they both burnt out??
Postby nemoxfishy » Thu Nov 08, 2007 8:49 pm
i got the exact same problem .... lowbeams are out... but highbeams work... help please
nemoxfishy
Postby Jai_Jai_Binks » Thu Nov 08, 2007 9:50 pm
Mole wrote:they both burnt out??
I don't know if they are burnt out.....they work for high beams and not for low beams. I'll have to put this car in storage if I can't figure out how to solve this issue and resurrect my lara.
Postby Midias » Fri Nov 09, 2007 5:40 am
h4 bulbs almost always burn out the low beam first and then the high still works try swapping one out. BTW on most cars if one low beam fuse goes both lights stop working.
Postby ASG14 » Sun Nov 11, 2007 12:20 am
The Low beams on my '96 Camry (9006) went out 2 days apart, haha. When one goes out, more current goes to the other. I;ve seen both go out within 1 week on several cars. So as other said, check the bulbs. :)
ASG14
Postby DatSRBoi » Sun Nov 11, 2007 12:54 am
Get a volt meter and turn on low beam. Ground one wire off the meter and stick the other one into the low beam prong on the harness. If no signal you might have a bad relay. Have fun searching for it.
Postby nemoxfishy » Sun Nov 11, 2007 8:09 am
wheres the relay for the low beams ???
nemoxfishy
Postby TadS » Sun Nov 11, 2007 2:58 pm
This happened on my parents ’00 Camry. I just replaced the bulbs, and everything was ok. Did you try swapping the bulbs out yet? If not try that, if so check the voltage at the socket.
TadS
Return to Toyota Camry
