SolaraGuy.com • View topic - Flex pipe on 98 camry 2.2l
Postby Midias » Mon Nov 12, 2007 5:53 pm
My wife has a leak on her 98 camry's flex pipe and I am going to weld a new one in. Anyone know the proper diameter I am thinking 2 inch but not sure. I searched and came up with the V6 specs only.
Postby .onetohate » Mon Nov 12, 2007 6:56 pm
how do you find out if there's a leak? - sorry to thread jack. LOL
.onetohate
Postby SC V6 » Mon Nov 12, 2007 7:13 pm
you can hear it... just have to climb under the car and listen/smell
SC V6
Postby TadS » Mon Nov 12, 2007 7:17 pm
2" sounds right. It's close enough anyway.
TadS
Postby Eye8Pussies » Mon Nov 12, 2007 8:34 pm
should be 2"
Postby Midias » Tue Nov 13, 2007 7:12 am
.onetohate wrote:how do you find out if there's a leak? - sorry to thread jack. LOL
Thanks for the replys guys
and for one to hate I hears the car being louder than normal. Then I walked around until I decided front or back of car then I reached underneath and felt for a leak. when I felt hot air I found my leak.
Postby .onetohate » Tue Nov 13, 2007 10:09 am
thanks fellas..
.onetohate
Postby Eye8Pussies » Tue Nov 13, 2007 1:03 pm
or you can use some seafoam and then you'll see where the leak is when in doubt ;)
Postby Midias » Tue Nov 20, 2007 5:45 pm
OK I got the old measuring tools out. In front I got 1.950 inch and .2043 in the back. Then I measured the entire section so I got a 6 inch flex with a 10 inch overall and 2"ID piping. I will post pics when I get it installed.
Postby {-_-} » Tue Nov 20, 2007 11:13 pm
Hi,
Where did you purcahse the 6 inch flex?
Thanks
95 LE Coupe
99K
{-_-}
Postby Midias » Wed Nov 21, 2007 5:19 am
{-_-} wrote:Hi,
Thanks
ebay from the seller performance-curve
Postby {-_-} » Fri Nov 23, 2007 4:44 pm
Thank you. BTW, the same seller has slightly lower prices (shipping) on his site www.performance-curve.com
With your setup, were you able to fit the pipes inside of the new flex piece? I am thinking of fitting the pipes inside of the flex using clamps instead of welding.
Thanks
95 LE Coupe
99K
{-_-}
Postby Midias » Sat Nov 24, 2007 7:56 am
One side can be clamped I think but the other I am not sure I need to find a time I can crawl under her car and do this thing. :-?
Postby Midias » Sat Nov 24, 2007 4:30 pm
OK it is done. First all only the side near the engine can be clamped the other side is not so lucky. You have just enough material to slip a bit of the pipe over and weld it on. Now before the picture here is some info. I used a 2 inch ID flex pipe with 6 inches of flex and 10 inch overall length.
1. I was welding on my back upside down.
2. It was a flux welded NO gas.
3. I have no training.
4. I shattered my wrist a month ago in a motorcycle accident
So get off my back about weld quality.
Postby {-_-} » Mon Nov 26, 2007 10:22 pm
Thanks for the pics and info. Your welding is not too bad. If I try to arc weld mine, I am sure I will burn holes in the metal. With my brother's help, I will take a shot at gas welding.
According to UPS, my order will be here tomorrow.
Thanks again.
95 LE Coupe
99K
{-_-}
Return to Toyota Camry
