SolaraGuy.com • View topic - Air Intake Resonator
Postby JMSinMaryland » Tue Dec 04, 2007 5:55 pm
I'm wondering if anyone else has removed their air intake resonator box from their vehicle? I am installing my Injen intake tomorrow and figured while I'm at it to remove the "AIR." It doesn't really seem to have a purpose other than possibly muffling the air a bit. Please give me some feedback if you've removed yours and what, if any difference, you notice. Thanks Jon.
Same concept as number 13 above.
JMSinMaryland
Postby PXLpainter » Tue Dec 04, 2007 6:00 pm
I thought that was some kind of moisture drain receptacle or something... anyway - it was in the way so I tossed mine when I put in my first SRI (Injen) as well - won't connect anyway - it's just sitting there.
Postby xet » Tue Dec 04, 2007 6:15 pm
took mine out, i believe it is to change the tone. when i took mine out it made it a bit deeper of a "growl" with no noticeable effects either way
1998 camry xle
2005 g35 coupe 6mt
xet
Postby NeFaRiOuS_SLE » Tue Dec 04, 2007 6:20 pm
Yeah, in our 1MZ once you get an intake, all the stuff designed for resonating/sound reduction would be useless; I've taken EVERYTHING out for mine, especially that "4-gallon jug" (the thing similar to #13 above) that became a major pain in the ass when I was trying to install my Highway Blasters.
Postby Ruski » Tue Dec 04, 2007 7:36 pm
It pointless remove it if your doing a cai, if not just leave it in there up to you, i didnt notice any noise diff or gains
Postby unbalancedwood » Wed Dec 05, 2007 7:21 am
turn your wheel on driverside inward, remove screws that are holding the protective plastic shield around your wheel well, (no screws) and pull that milk jug down and out.
it wont effect anything, if you did a CAI it would alleviate more room to work with/cold air to suck.
unbalancedwood
Postby Sebas007 » Wed Dec 05, 2007 7:56 am
xet wrote:took mine out, i believe it is to change the tone. when i took mine out it made it a bit deeper of a "growl" with no noticeable effects either way
The air intake resonator box purpose is to keep manufacturer respecting Db laws...it lowers the decibels.
Postby DatSRBoi » Wed Dec 05, 2007 8:38 am
Taking the bottom part out will have no big difference in performance considering that section of your fender does not get a full chunk of fresh air unless you remove the fog lights. I would take the time to remove it but make sure you put the old bolts or anything back into the car or else you will be annoyed with the fender flopping at high speeds.
Postby ASG14 » Fri Dec 07, 2007 1:14 am
I removed mine like 40k miles ago and still have the stock intake system.
ASG14
Question
Postby JMSinMaryland » Fri Dec 07, 2007 8:36 pm
Did removing it with the stock setup result in any change in dB? I'm thinking of either removing it completely and routing some additional cold air in or cutting out the bottom half to act like a funnel and route some additional cold air in. Let me know.
JMSinMaryland
Postby Ruski » Fri Dec 07, 2007 10:11 pm
You hardly notice a diff in sound
Postby ASG14 » Mon Dec 10, 2007 11:32 pm
Yeah, if there even was a difference, it was like 1db.I'm planning to run a Ram Air (from bumper) to the stock airbox when I have time to design one. Summer most likely.
ASG14
Postby CorCamrySE » Wed Dec 12, 2007 1:46 am
haha i removed this thing out of your car today!
mucho work for no gain in power haha
decided weather u wanna cut out the lower fenderwell lining/splashshield on the drivers side yet jon?
MCV30 - 1MZ-FE
2003 Lexus ES300
CorCamrySE
Postby sahuddleston » Wed Dec 12, 2007 3:25 am
took mine out 2 years ago, no issues. cant tell a difference in sound either.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby TheKevin » Mon Jan 07, 2008 6:31 pm
no sound? not even a little a little throatier?
'07 Scion tC
'92 Camry V6 LE
'91 300ZX TT
TheKevin
Return to Toyota Camry
