SolaraGuy.com • View topic - Headlight issues
Headlight issues
Headlight issues
Postby Midias » Tue Dec 04, 2007 9:14 pm
Well the girlfriend just go home and is very upset because her high beams don't work. I quickly went outside and both lows work but no high. The switch appears to work and the indicator on the dash works. It is about 11 pm here now and 15 degrees out so I am not going to mess with it but I am think relay unless both lights decided to die on the high beam which seems unlikely. So any ideas?
Postby Eye8Pussies » Tue Dec 04, 2007 10:14 pm
check the bulbs and then the relays...
stranger things have happened.....both of my gf's low beams didn't work...so me and my buddy took time off from my tranny swap to search through all her fuses and relays....
in the end it was the bulbs...it was a sad sad day for us...lol
Postby Midias » Wed Dec 05, 2007 6:51 am
Well glad I did not go too crazy I tried swapping the relay from my solara in but no dice so I found an old H4 bulb from my bike before I upgraded popped it in and I got high and low. Damn that was weird only having low not high.
Postby Eye8Pussies » Wed Dec 05, 2007 11:20 am
lol...see?!!?
sometimes things can be stupidly easy and we always find the hardest way to try and fix it...haha...
Postby Chinky420 » Wed Dec 05, 2007 3:25 pm
yeah, i've heard that the high beam filament has been known to go out before. tres weird though, since high beams are used less than 5% of the time that the lowbeams are used.
Chinky420
Return to Toyota Camry
