SolaraGuy.com • View topic - 17X8.5 wheels 235/45-17
Postby 1kdude » Fri Apr 18, 2008 10:37 pm
I really like this setup on my99 Camry, rear fenders had to be rolled. Rota wheels, $550 for the set, 35mm offset. 21 # each wheel.
BS Potenza RE050 pole position tires work very well, so far better than Dunlop SportMaxes.
Not sure how to post pictures but I do have them, a well designed site should make this easy.
1kdude
Postby white07cam » Sat Apr 19, 2008 12:07 pm
if you upload your pics to photobucket, it will create img tags for them..
white07cam
Postby 1kdude » Thu May 01, 2008 6:42 pm
I'll need a bit more information to do that?
1kdude
Postby woa_its_j3ff » Thu May 01, 2008 7:19 pm
no you dont. upload it on photobucket.
select the thing that says "IMG CODE" under your pic, then take that link and paste it here.
there you go. you dont need more info than that.
Return to Toyota Camry
