SolaraGuy.com • View topic - HID Problem?
HID Problem?
HID Problem?
Postby M_ABILLONES » Thu Aug 21, 2008 6:38 am
I just installed a new set of hid kits for my 08 Camry and now the right headlamp seems to be "flickering" from time to time....now i've never seen an hid kit do this before so Im a little bit baffled...could it be that the bulb is dying out?...the ballast dying out?...what do you guys think the problem is?
Mark
M_ABILLONES
Postby prsolara » Thu Aug 21, 2008 8:10 am
Look at the cables and check if they are not contacting any metal from the car, also the ballast. Same thing happened to me. Hope that this help
prsolara
Postby TLMNICK » Thu Aug 21, 2008 8:42 am
If you didnt use a relay harness.....I suggest you do. The power comming directly from the headlight wires isnt always enough to run a ballast, especially if its the older (bigger) style ones. If you need a pic of what the relay harnes looks like, let me know.
TLMNICK
Postby mazen222 » Thu Aug 21, 2008 9:29 am
disable your day running lights.... i heared the flicking is caused by that
mazen222
Postby prsolara » Thu Aug 21, 2008 9:47 am
mazen222 wrote:disable your day running lights.... i heared the flicking is caused by that
dont think so, i disable mine and they are still flicking!
prsolara
Postby M_ABILLONES » Sun Aug 24, 2008 9:06 am
Forget the flickering...now it looks like a strobe light!
M_ABILLONES
Postby Mole » Sun Aug 24, 2008 9:26 am
i had a kit from the earlier days...when it flickered it died shortly after.
Postby M_ABILLONES » Sun Aug 24, 2008 9:37 am
That's what I'm hoping to happen soon..for the hid to die out...i don't think it's the bulb's doesn't flicker...it just dies out without any warnings...could be the ballast...
M_ABILLONES
Return to Toyota Camry
