SolaraGuy.com • View topic - Codes....
Codes....
Codes....
Postby JamesT » Wed Sep 10, 2008 5:42 pm
So today my cel came on. Pulled P0153. The strange thing is that I didn't pull P0150. Does that mean anything to anyone?
Also,
P0150: o2 circut malfunction (bank 2 sensor 1)
P0153: o2 sensor slow response (bank 2 sensor 1)
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby Eye8Pussies » Wed Sep 10, 2008 6:09 pm
what have you done to your car performance-wise?
p0153 is usually thrown when the car is running lean and the exhaust is overheating the o2 sensor, thus, the slow response
it's mostly common on boosted applications and people with massive vacuum leaks
Postby Mr_Krispy1183 » Wed Sep 10, 2008 6:17 pm
^I believe James is running Damon (CamryOnBronze)'s SC.
Postby JamesT » Wed Sep 10, 2008 6:18 pm
No serious performance mods yet. Although I do have Damon's supercharger on the way...
The question I have is that if it were a vacuum leak wouldn't the o2 sensors on both banks have this issue?
BespokeAutoInterior
JamesT
Postby Eye8Pussies » Wed Sep 17, 2008 9:51 am
you'd think so....but that's not always a given. same with misifres from vacuum leaks....doesn't really explain why sometimes only a couple of cylinders will misfire.
it's a lot less of a guessing game though, when you get random misfires though lol
Postby JamesT » Wed Sep 17, 2008 2:54 pm
I've just started replacing gaskets from the throttle back... I assume I will eventually fix it.
BespokeAutoInterior
JamesT
Postby Eye8Pussies » Wed Sep 17, 2008 3:18 pm
that's one way...though, not the most efficient way...try using throttlebody cleaner and spraying it around the engine bay
the other possibility, of course, is that there is actually something wrong with the 02 sensor and needs to be replaced
Postby JamesT » Wed Sep 17, 2008 3:58 pm
Eye8Pussies wrote:that's one way...though, not the most efficient way...try using throttlebody cleaner and spraying it around the engine bay
Genius! If only I had thought of that a few days ago... :oops:
BespokeAutoInterior
JamesT
Return to Toyota Camry
