SolaraGuy.com • View topic - Flex Pipe
Flex Pipe
Flex Pipe
Postby platypusfetch » Sat Oct 04, 2008 5:33 am
I just got off the Phone with a toyota STEALER. I think I have a hole in the flex pipe (V6) My dodge avenger -->$272.93 TOTAL
Toyota's unseen quote......You had better sit down......
For just the Pipe---------------------------->$1,463.00
Gaskets-------------------------------------->$25.00
LABOUR-------------------------------------->@ $85.00
_______________________________________________
TOTAL----------------------------------------> $1573.00
TAX @ 14% gst and Pst
GRAND TOTAL---------------------------------->1793.22
Anyone got any better ideas.....cause this answer is not going to work for me
Thanks in advance
Platy..
platypusfetch
Postby PhreakdOut » Sat Oct 04, 2008 6:00 am
That pipe must have the catalytic converter built into it. Muffler shops carry universal flex sections. They cut off your old one and weld in a new section. Should be under $200 CAD.
Postby Dawgz » Sat Oct 04, 2008 6:40 am
In the dealer's defense....they replace parts rather than cutting out the problamatic section and installing the new one and then welding it on....Muffler shops on the other hand will do what was mentioned above.
It would be more of a hassle for a dealership to cut out the old piece and install a new one rather than installing a whole new pipe, thats what they have been doing and thats what they will do in the future. So for jobs like this, you should avoid the dealership and go to a muffler shop.
GL!
Postby Midias » Sat Oct 04, 2008 6:43 am
For my wife's camry I just cut the old one out and welded a new one in cost me about 20 dollars.
Postby Dawgz » Sat Oct 04, 2008 7:50 am
Midias, u make damn good use of that welder of urs! lol.
Postby platypusfetch » Wed Oct 08, 2008 6:05 am
thanks fellas. went to check out a local guy......mom and pop shop
mandrel bent 2.5" piping to replace all the weird bends at the end of the stock "headers" (found some leaks in it at the pinch welds) + replace the flex pipe.
$175-200 + tx.
Thanks again
Platy
platypusfetch
Return to Toyota Camry
