SolaraGuy.com • View topic - Restoring hazy headlights
Postby GTX » Tue Jun 16, 2009 3:03 pm
My Camry's glasses are all fogged up and hazy. :(
What do you guys use to fix em up? I tried Meguiar's PlasticX and it worked a little, but the haze came right back after about a month.
99 Camry LE V6
GTX
Postby BLACK V6 » Tue Jun 16, 2009 3:12 pm
Light sanding w/ 2000 sandpaper and then a quick 3 step buff for me.
My results:
BLACK V6
Postby Solarizona » Tue Jun 16, 2009 3:18 pm
Mine were quite a bit worse than that, and I used a Crystal View pack I got from WalMart. About a 1 1/2 years later, headlights still look perfect. I had tried several other products and none were even close to matching the Crystal View. I think you can get it cheaper on line, but I think they sell it at pretty much any WalMart.
http://www.myheadlight.com/
Solarizona
Postby BesI » Tue Jun 16, 2009 3:32 pm
Like you said i do too use the same thing and works out for me on the other cars.
The way that i do it is that i put some on the headlight cover the whole thing with that and let it dry for couple minutes, after that use towel or paper towel and try to clean it up until you can see the headlight.
BesI
Postby GTX » Tue Jun 16, 2009 3:56 pm
Thanks guys!
99 Camry LE V6
GTX
Postby D-money » Tue Jun 16, 2009 4:16 pm
I think the lights on the camry are glass not plastic those products wont work all you need is highspeed buffer and fine compound like this http://www.youtube.com/watch?v=l2O7fDcs ... re=related
D-money
Postby jetbtkng » Tue Jun 16, 2009 4:25 pm
thats what i do, polishing compound, works great............ :drinking:
Return to Toyota Camry
