SolaraGuy.com • View topic - Oil Filter Wrench
Oil Filter Wrench
Oil Filter Wrench
Postby RON » Tue Nov 17, 2009 10:47 pm
Just got this....works nice in tight places like our car and is adjustable to fit filters that may have slightly different sizing and flutes. I don't like filter caps, unless you can get one with a *perfect* fit (Toyota). That's because you can get it stuck on top of the filter..no biggie..just a pain. You can't tighten the filter with this, but you're>>>>>>>>>>NOT SUPPOSED TO TIGHTEN WITH A WRENCH :o
Link:
http://www.brandsport.com/ctam-2506.html
RON
Postby ToyoSolV6 » Tue Nov 17, 2009 10:55 pm
yeep works well i have it too.
Postby alltrac92 » Wed Nov 18, 2009 5:03 pm
I use this it has 4 contact points and you can use a 3/8 square drive or 7/8 open combination wrench for the tight spots.
alltrac92
Postby Mole » Mon Nov 23, 2009 12:49 pm
i just use a 24'' screwdriver for filters that don't want to come out.
for all other times it's this :
Postby 99BlackSandv6 » Mon Nov 23, 2009 9:36 pm
I've used all of those at one time or another....I still prefer the caps.
Postby RON » Mon Nov 23, 2009 9:53 pm
99BlackSandv6 wrote:I've used all of those at one time or another....I still prefer the caps.
Is it just me...or is it tighter than S$$T in there? I don't see much wiggle room in the V6 with the filter just below the headers. No problem if you just have to do it by hand (tighten)..but if you have to use something to take it OFF, then any kind of wrench with a handle will be tight indeed. That's why a cap or top grabber (like I posted here) is desireable. Even then, it's tight using a ratchet.
RON
Return to Toyota Camry
