SolaraGuy.com • View topic - Jet Performance Throttle Body Spacer for Camry
Postby twinjetguy » Tue Nov 24, 2009 1:29 pm
Hey Guys,
Just got back from driving to Jet Performance. I bought myself a throttle body spacer from them that works on the 3.0 1MZ Camry motor. It is originally for the Tacoma 3.4 5VZ motor. If you are going to order it, make sure that you order part# 62133! DO NOT order part# 62136 because it costs more. It's the exact same part, it just comes with different hardware and that is what makes it cost more.
Keep in mind you will have to provide your own bolts, you can't use the ones from the kit. I picked up the bolts I needed at True Value for a whopping $5. The kit even comes with the gaskets that you need. I will have pics of it up soon, letting the motor cool down before I install.
Remember, order part number 62133. If you order it through Summit Racing, they only charge $71.95. Here is the link to Summit if you want it. Ignore the pic of the throttle body they have on there, they will send you the right one as long as you use the correct part #
http://www.summitracing.com/search/?...33%20jet&dds=1
I'm not an alcoholic, I'm a alcohol enthusiast!
twinjetguy
Postby Midias » Tue Nov 24, 2009 3:20 pm
Thanks
Postby EEngineer » Tue Nov 24, 2009 5:32 pm
do those things actually do anything?
it's always been a myth.
let us know if u gained anything...better yet...dyno it before and after
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby twinjetguy » Tue Nov 24, 2009 7:14 pm
EEngineer wrote:do those things actually do anything?
You know, to be honest, I don't know. I figured what the hell? I don't have access to a dyno so I won't be doing that anytime soon, lol. If I ever do get access to one, I will test it with and without the spacer on.
EE, you have access to a dyno, you need to try one out!
twinjetguy
Return to Toyota Camry
