SolaraGuy.com • View topic - Toyota Fuel Injector Cleaner
Postby RON » Fri Nov 27, 2009 12:37 am
It's not well known, but Toyota has it at the dealers and it's supposed to be very good. It's an *in the tank application*...not a fuel line application.
I found the PN for Toyota: 08813-00080DS
You can order it here. Just put in that PN on the PN Search function.
Toyota Fuel Injector Source for ordering:
https://www.toyotapartscenter.net/toyotaoemparts.html
RON
Postby RON » Fri Nov 27, 2009 12:53 am
Looks like someone else here found it a while back:
Posted: Sat Jul 28, 2007 10:43 pm Post subject:
I'm at 103k. I'm a V6 Auto.
Here are the maintenance part numbers:
Tbelt 13568-09080
waterpump 16100-29085
ac/alt belt 90916-02401-83
p/s belt 90080-91088-83
thermostat 90916-03129
thermostat gasket 16325-62010
crank seal 90311-40022
transpan gasket (automatic) 35168-33031
atf fluid 00718-ATF00 (5)
air filter 17801-03010
efi cleaner 08813-00080-DS <<<<<<<<
RON
Postby PeterKesel » Tue Dec 29, 2009 3:51 am
Your maintenance part is good.HID ballast starts the lamp and let the electricity to flow constantly through the bulb to keep the light on. In simply speaking it controls the electrical current running through the glass bulb. It has been divided into three categories that are used with high intensity discharge lights. These are magnetic ballasts, electronic ballasts, and digital ballasts.
HID Ballast
PeterKesel
Postby Chinky420 » Tue Dec 29, 2009 11:09 am
freakin spam post
thanks for digging up old answered posts, peter.
explain exactly how HIDs relate to EFI cleaners?
maybe you thought we were talking about blinker fluid? :drinking:
Chinky420
Postby WUTANGCLAN » Tue Dec 29, 2009 12:33 pm
Haha I agree that was random
WUTANGCLAN
Return to Toyota Camry
