SolaraGuy.com • View topic - 1MZFE Emission HC is at limit of 54 Suggestions?
Postby 1kdude » Fri Feb 25, 2011 10:10 pm
My Gen 4 LE V6 Camry with MT has 140K mi, gets 30 mpg on the freeway but is at the emission limit, other #'s are CO: meas .07, Max 0.5 NO: meas 295, meas 430.
I would like to sell this car soon, are these CA smog #'s a factor? Any suggestions as to how to lower the HC #?
Thanks! :D
1kdude
Re: 1MZFE Emission HC is at limit of 54 Suggestions?
Postby JavaJoe_2 » Sat Feb 26, 2011 9:41 am
Any leaks in the exhaust? Once, mine had an exhaust leak near the o2 sensors and it richened up the a/f. It thought it was running lean and was adding extra fuel to compensate for it. The pipe going to the cooler was broken, most likely caused by a weak/broken rear engine mount.
Got Boost?? :sweet:
JavaJoe_2
Return to Toyota Camry
