SolaraGuy.com • View topic - 245/45-18 on Gen 6?
245/45-18 on Gen 6?
245/45-18 on Gen 6?
Postby SolaraPete » Sat Oct 13, 2012 7:38 pm
My wife drives a 07 Camry (SE V6) with the 18x7.5 TRD wheels. Currently it has 225/45's on it which need to be replaced. Ive got a friend with a set of 245/45s that i can get for cheap, but im concerned they might be too wide for a 7.5" wheel. Anyone know if this size tire will be safe to mount, and if there will be any fitment issues?
:cheers:
SolaraPete
Re: 245/45-18 on Gen 6?
Postby cartang » Sat Oct 13, 2012 8:18 pm
I have 245/45/18 on lexus gs 430 rims ,check , my post by cartang , I hope it help
[IMG]http://i275.photobucket.com/albums/jj307/cartang1/007-2-1.jpg[/IMG]
Camry 99, 5sp manual, SC,CPE intake,OBX headers, Jim's fuel system,Walbro pump,Greddy exhaust,Exedy 1 clutch,Fidanza flyweel.
Camry 07, V6,TRD cat back,Fujita CAI, GS 430 rims
cartang
Postby SolaraPete » Sat Oct 13, 2012 9:29 pm
Thanks cartang! It appears the gs430 rims are the same offset as my TRD wheels, so at least i know they wont rub. However your wheels are 18x8 - has anyone mounted a 245/45 on a 18x7.5?
SolaraPete
Postby xpeed » Mon Oct 15, 2012 1:19 am
245/45 on a 18x7.5 is a bit excessive. You might get slight rubbing on the struts, so check how much room you have between the struts and the tires. Wider tires gives you better traction and ride quality. It helps absorb more of the road than a 225/45 would, but, like I said, it might be too wide for your 7.5" width wheel. At most, I would go 235/45 on them.
2013 Hyundai Genesis Coupe 3.8 R-SPEC
xpeed
Postby ToyoSolV6 » Wed Oct 17, 2012 9:49 am
when i rocked 17x7 with a +45 i used 245's up front and they were good for the rear it hit. Whats the offset on your wheels pete?
Postby SolaraPete » Fri Oct 19, 2012 8:25 pm
Offset is a +45on a 17x7.5. Keep in mind this is for my wife's 07 Camry, so there might be more room than on the Solara.... Did your 245s hit on the inside or outside?
SolaraPete
Postby ToyoSolV6 » Mon Oct 22, 2012 9:46 am
SolaraPete wrote:Offset is a +45on a 17x7.5. Keep in mind this is for my wife's 07 Camry, so there might be more room than on the Solara.... Did your 245s hit on the inside or outside?
When i tried doing 245's for the rear it kept hitting my struts and springs. the front cleared no issues.
Postby SolaraPete » Tue Oct 23, 2012 7:48 pm
Well sounds like its a 50/50 shot so I'm gonna give it a try and will report back once i get em mounted. Thanks for everyones help - much appreciated!
:cheers:
SolaraPete
Return to Toyota Camry
