SolaraGuy.com • View topic - engine light comes on after fill up
Postby bonargar » Mon Apr 12, 2004 3:04 pm
I need help.
After filling my gas tank, my check engine light came on. How do I reset it and what can be the potential problem?
98 camry LE
bonargar
Postby Jai_Jai_Binks » Mon Apr 12, 2004 3:12 pm
Assuming this to be bad gas...I'd get as close to empty and then fill her with NAME BRAND gas...and work from there. As far as resetting stuff...just unplug the negative from the batter for 5 minutes and replug to see if it helps...but i think what i suggested first is the thing to do!
Postby geminimouse » Mon Apr 12, 2004 3:28 pm
Wouldn't putting the gas cap improperly make the check engine light come on too?
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby bonargar » Mon Apr 12, 2004 3:34 pm
I guess that would cause it. But in this case , the gas cap was put on correctly.
bonargar
Postby trdkamuri51o » Tue Apr 13, 2004 6:42 am
i would say that it is the gascap throwing the code. like someone else said unplug the negative terminal of the battery, but instead of waiting just press the brake pedal for 5 seconds to drain any power from the ecu to fully reset it.
or go to kragens/pepboys for a code reader.
id bet its a gascap not properly screwed on light (i had the same thing even though it was fine. replaced the gascap and it went away.
trdkamuri51o
Postby Mole » Tue Apr 13, 2004 9:12 am
it might be a bad gas cap as well.
Postby dan99solara » Mon Apr 19, 2004 5:09 am
make sure you put the gas cap on and twist it until it clicks and cant twist anymore. if its not properly tighend it sometimes makes the check engine light come on.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Return to Toyota Camry
