SolaraGuy.com • View topic - <05-29-08> result is in Sand Mica Limited TURBO!
For the one guy with it, and the few guys planning it...
Postby tacti » Mon May 26, 2008 4:12 pm
tomorrow, i'm going back to the shop and finish my exhaust work.
I will probably go to the tuner on thursday or friday, and hopefully it'll fix it.
I got Magnaflow Metallic core high flow cat, and putting 2.5 piping from the downpipe alway back.
Tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby gnegroni » Mon May 26, 2008 6:13 pm
Congrats tacti... your post reached the 9th page! :sweet:
Hope you can find the culprit!
gnegroni
Postby tacti » Thu May 29, 2008 1:26 pm
Final (?) Update! 5/29/08
Quite a bit updates since last update.
1. Moroso Breather Tank Installed
Please visit this thread for more info
2. Exhaust Upgrade
I had 2.5" Catback, and was going to change the midpipe and Catalytic Converter to High Flow Cat, but just because the shop did not have the 2.5" in stock, I went with 3" downpipe back.
For now, I have Magnaflow High Flow Cat and Straight Thru Muffler.
because of drone, I probably will add some resonator soon.
3. Unichip Tuner
Finally i took may car to the unichip tuner.
they found the stalling issue was a little bit of tuning issue but more of the BOV spring.
the BOV spring is too hard for the Solara's vacuum to open it up.
set the BOV to the softest, and still barely opens.
shop is looking for a softer spring to replace it.
they also tuned the unichip to get a better a/f ratio.
now it's right around 11.5~11.7 at most rpm under boost.
I know I know... you are waiting for the final number....
at the tuner's dyno, i got 228 HP at the wheels.
Since it is at the different shop's dyno, I the number is not very accurate to compare with the previous number.
I will bring my car to the original shop when i do the resonator, and will do the dyno again.
Tact
RX-8 Page
Solara Page
SG Map
tacti
Postby Sebas007 » Thu May 29, 2008 2:24 pm
Nice update ! The nightmare is gone !
228 whp nice number but let's wait for you to confirm it against the other dyno. Nice stuff Tact ! :D
Postby anwagbo3000 » Mon Jun 02, 2008 4:42 pm
228 sounds like a pretty good number, this is just the start, good work, could you pm your setup
anwagbo3000
Postby anwagbo3000 » Mon Jun 02, 2008 4:47 pm
this is for the 2az engine correct
anwagbo3000
Postby tacti » Mon Jun 02, 2008 6:29 pm
I made a small change on my BOV Setup in order to fix my stalling problem.
(Thanks for Turbonetics for the tip!)
I T-tap the boost reference line from the charge pipe to waste gate, and connect the new line to the BOV.
This made the BOV to release the pressure quicker.
The Pusssshaaa sound from the bov got much smaller, but it did make my RPM more smooth.
will drive with this setup for a while and see how much difference it makes. I still may need small adjustment on the BOV, but for now, I'll drive around with this.
RX-8 Page
Solara Page
SG Map
tacti
Postby tacti » Mon Jun 02, 2008 7:36 pm
Instead of PM, I will post my current setup.
It was not just a simple plug and play install, but finally i got to the setup it's pretty stable, and satisfactory.
Hope this will provide some hints for some of you guys if anyone decide to follow my pass :drinking:
Model: 2004 Solara SE
Engine: 2AZ-FE
Transmission: Automatic
Kit: Turbonetics Scion tC Automatic Kit 2004-2005
INCLUDED IN KIT
• T3/T4 E-50 Ball Bearing Turbo
• Spearco intercooler
• Raptor blow-off valve
• Evolution wastegate
• Unichip engine management
• Stainless oil feed line
• Taps for oil return and oil feed fittings
• Stainless down-pipe with wastegate dump-tube
• Cast ductile-iron exhaust manifold
• Aluminum intercooler pipes
• Silicone hoses
• High flow air filter
• 4 drop-in Motron high flow injectors
• T-bolt & V-band clamps
• Nuts, bolts and fittings
Additional Stuff
• Extra Pipings
• Moroso Breather Tank w/ SS line
• Transmission Cooler
• 3" Exhaust w/ Magnaflow High Flow Cat and Muffler
• Cold Air Extension (I had it already...)
• Zeitronix zt2 with LCD Display (Air Fuel Ratio / Boost / Exhaust Temp)
Installation
The installation went fairly smooth.
The things different from the installation instruction from Trubonetics.
• The Battery Location of solara is different from the tC's
- I moved the battery location, used Cold Air Extention
• Instead of Oil Line Tap, the line is welded to the Oil Pan
• Unichip comes pre-tuned, but need some re-tune
• BOV Spring set looser
• Boost Reference line connect to both BOV and Waste Gate
• Down Pipe does not connect to the Solara's Mid-pipe.
- However, Solara's Down pipe fit perfectly to the t'C's Down pipe
If you have any questions, just let me know.
Tact
RX-8 Page
Solara Page
SG Map
tacti
Postby philosophicaljt » Mon Jun 02, 2008 9:56 pm
How is Colletti treating you? I have known them forever, and I sold my old prelude to Steve, the owner.
What were you doing autocrossing? Sounds like you weren't ready if you are having tuning issues!!!!
did you have fun?
2004 Solara SLE V6
Search
philosophicaljt
Postby tacti » Tue Jun 03, 2008 10:57 am
they are good.
really good people and great work.
loved autocross and will go back again.
also, i'll probably go to their road race event and see if steve could let me ride next to him.
Tact
RX-8 Page
Solara Page
SG Map
tacti
Postby gnegroni » Tue Jun 03, 2008 5:26 pm
tacti, I am happy that you found a few more horses... although very happy that you had the driveability issue resolved.
Hope everything keeps on working awesomely!
:sweet: :sweet: :sweet:
gnegroni
Postby michaels artic frost » Sun Jun 08, 2008 1:58 pm
Congrats again Tact...true pioneer of the Gen 2... WTG Tact!!!
-Michael
Updated 06/01/12: Michael T's
Postby PXLpainter » Sun Jun 08, 2008 4:35 pm
Tact - this is awesome man! Way to grow some serious mod-man respect with this project and for pioneering the Gen 2 i4 performance mods! :up:
Postby liltimmy1313 » Sat Oct 11, 2008 11:42 am
overall, how much did this cost you?
I'm bettin it was quite a pretty penny.
My guess is 4G's...
well anyway, it looks sick, if i had money you can bet i'd be doin that to my 'lara
2004 Toyota Solara V6 SLE, stock
but not for long :D
http://liltimmy1313.deviantart.com/art/ ... R-97881991
liltimmy1313
Re: <05-29-08> result is in Sand Mica Limited TURBO!
Postby DriDed » Sat Feb 19, 2011 9:56 pm
I checked out one of tacti3's ytube videos and it stated that his turbonetics Solara @ 8PSI has 225 fwhp....
This Scion TC made 277 whp 270 tq with the same turbonetics kit at only 9 psi, but the car is a manual.
There is a manual Scion TC on youtube that made 290hp with the Dezod S1 kit @ 9psi:
I am gonna go with the Dezod S1 kit.
When my car is all setup with the dezod s1 turbo and necessary mods and exhaust, it should be about 250hp at 9psi since it is auto.
haha I can't wait the day that my Solara is boosted.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Return to Gen 2 Forced Induction
