SolaraGuy.com • View topic - Tire inflation
Stock talk about Solara
Tire inflation
Tire inflation
Postby wkbrdr91 » Fri Jan 21, 2011 3:50 pm
How much PSI should I be putting into my tires?
I have always just done the typical 32 PSI because thats what my dad has always done... and I saw thats how much the stock tires are supposed to get.
I have 18 inch rims and Michelin HXMXM4 P235/45 R18 tires
2006 Solara Sport
wkbrdr91
Re: Tire inflation
Postby mig0s » Fri Jan 21, 2011 4:18 pm
I got 35 in all four in my tires.
mig0s
Re: Tire inflation
Postby DriDed » Fri Jan 21, 2011 7:21 pm
If 32PSI worked pretty good for you then keep using that amount on your tires.
I usually pump 32-33 psi on my car's stock 16" tires.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Re: Tire inflation
Postby wkbrdr91 » Fri Jan 21, 2011 8:50 pm
I feel like it should be given more than 32... I mean I have not had any "problems" but it could hurt gas mileage.
I believe the bigger the rim/lower the profile the higher the PSI is needed... therefore you putting the same amount of PSI into 16" rims as an 18" rim doesnt make sense.
2006 Solara Sport
wkbrdr91
Re: Tire inflation
Postby 1gSE » Fri Jan 21, 2011 9:29 pm
when I worked in the tire business, anytime a customer went with a larger wheel/lower profile tire, we always bumped the pressure up to about 38 to 40 psi. That's about where mine are right.
Solara-M62 @ 5.5psi
1gSE
Re: Tire inflation
Postby wkbrdr91 » Sun Jan 23, 2011 11:51 pm
1gSE wrote:when I worked in the tire business, anytime a customer went with a larger wheel/lower profile tire, we always bumped the pressure up to about 38 to 40 psi. That's about where mine are right.
What size rims do you have? I just upped mine to 36 for now.. the edges of my tires are completely bald (well the ones in the back, they spent WAYYY too much time up front from lack of rotating for the first 15k miles) but the middle of all tires are fine... though do need replacing soon. I spotted a gen 2.5 with 18 inch rims... maybe ill have to switch em out lol :evilbat:
2006 Solara Sport
wkbrdr91
Re: Tire inflation
Postby 1gSE » Mon Jan 24, 2011 4:22 am
18in
Solara-M62 @ 5.5psi
1gSE
Return to Toyota Solara OEM
