SolaraGuy.com • View topic - Shock Tower Brace
Stock talk about Solara
Shock Tower Brace
Shock Tower Brace
Postby mfeisen » Sun Feb 13, 2011 2:00 pm
There's a factory shock tower brace on my 02 convertible. Would like to reduce chassis flex and was wondering if replacing the stock unit with a TRD or other after market unit is worth while.
I'm amazed at how much the car flexes while driving over minor bumps/dips and other then installing a roll bar, not sure what else can be done. Has anyone attempted to reduce the chassis flex on the first gen. convertibles?
mfeisen
Re: Shock Tower Brace
Postby DriDed » Mon Feb 14, 2011 6:41 am
I upgraded to the TRD strut brace on my Solara and the stock one went to my dad's Camry (did not come with one stock). With only the TRD strut brace installed, the Solara felt a bit (and I mean a bit) more stable on the corners but the major benefit is a better looking engine bay.
Go for the TRD rear sway bar as well as lowering springs/ shocks (or coilovers) in addition to the strut brace, you will definitely feel the difference then.
When you have all the available suspension parts installed, you will be driving a different car.
I plan to install lowering springs and shocks soon, possibly this summer if I get a good amount of money saved up from my job. I already have the TRD strut brace and TRD rear sway bar installed on my Solara.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby DSM_Lara » Mon Feb 14, 2011 2:24 pm
The factory tower bar is the same. They made the TRD strut tower to clear the Supercharger...
DSM_Lara
Postby 99BlackSandv6 » Thu Feb 17, 2011 3:40 pm
I'm with Dri on this one. It's mostly to look good.
I'm also with DSM, it's mostly to clear the supercharger. :lol:
Postby KILLA CAM » Mon Feb 28, 2011 12:48 am
The TRD strut bar will only help cosmetics. If your goal is to reduce chassis flex, then look up the Ultra Racing underbody braces. That's where you should spend your money.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby mfeisen » Sat Mar 12, 2011 9:17 am
Thank you all for the input. I now have a Whiteline RSB and that's all I plan to do for the handling part of the equation. One of the measures that the OEMs take when producing a 'vert is to soften the suspension to allow the chassis to flex more to compensate for the lack of rigidity. Lowering the car and adding stiffer springs will enhance handling, but you run the risk of making the overall ride worse on a 'vert.
I've looked at the Ultra Racing bracing, but not sure that it'll work in my case. The company ASC performed the 'vert conversions on the first gen models and they apparently added an X-brace to the rear underside. This X-brace may pose clearance problems when trying to add the Ultra Racing rear bracing.
I was hoping that someone with a first gen 'vert may have done this or something else. A lot of these aftermarket accessories are geared towards the coupes. Perhaps I'll email them. but beings that they're in Malaysia, not sure that my problem can fully be understood. I forget what they call the Solara over there and not even sure if they have 'verts over there.
mfeisen
Postby DriDed » Sat Mar 12, 2011 1:17 pm
when you install the ultra racing underbody brace, you are supposed to remove the factory x brace before installing the UR brace.
+TRD rear sway bar
DriDed
Return to Toyota Solara OEM
Users browsing this forum: Google [Bot] and 9 guests
