SolaraGuy.com • View topic - possible throttle prob
Stock talk about Solara
Postby OkcSolarafreak » Sun May 01, 2011 8:44 pm
Recently my car has had this strange problem. My gears feel like they are sticking but its not a trans problem. Whenever its in first ( its an automatic) it doesnt want to shift to second until i over rev and let off the gas, and than its fine until i try to floor it and my rpm shoot up but my throttle has no response it just keeps going like im not doing anything and wont shift. I replaced the tps and going to replace the maf sensor. Any ideas what the problem might be or solutions would help me out alot.
Can't prove it!
OkcSolarafreak
Re: possible throttle prob
Postby GzNutz » Mon May 02, 2011 3:37 pm
Can you give us a little more info as to the year and engine of your lara?
Postby OkcSolarafreak » Mon May 02, 2011 6:05 pm
its a 99 v6 1mz with supercharger
Can't prove it!
OkcSolarafreak
Postby OkcSolarafreak » Mon May 02, 2011 6:08 pm
its a 99 1mz with supercharger( if that matters)
Can't prove it!
OkcSolarafreak
Postby OkcSolarafreak » Tue May 03, 2011 2:55 am
its a 99 v6(1mz), its looking like a open or short circuit from the codes i pulled either the knock sensor, valve posi or the heated o2 bank sens1, im starting to think my computer is going out but im not sure. also i recently added some fuel system cleaner and these problems occured the next day for the most part.
Can't prove it!
OkcSolarafreak
Postby onefiend » Thu May 05, 2011 8:31 am
OkcSolarafreak wrote:its a 99 v6(1mz), its looking like a open or short circuit from the codes i pulled either the knock sensor, valve posi or the heated o2 bank sens1, im starting to think my computer is going out but im not sure. also i recently added some fuel system cleaner and these problems occured the next day for the most part.
what type of fuel system cleaner did you use? Techron or Seafoam?
2007 Camry SE V6
onefiend
Postby OkcSolarafreak » Thu May 05, 2011 10:09 am
used gumout im pretty sure it screwed something up or cleaned it good enough to clog something
Can't prove it!
OkcSolarafreak
Postby 1gSE » Thu May 05, 2011 10:24 am
what codes are you getting?
Solara-M62 @ 5.5psi
1gSE
Postby OkcSolarafreak » Thu May 05, 2011 10:28 am
Last time i checked it popped up with p0330, 420,1410,135
Can't prove it!
OkcSolarafreak
Postby 1gSE » Thu May 05, 2011 10:45 am
replace the o2 sensors, do the knock sensor rewire and then see if your still getting CELs
Solara-M62 @ 5.5psi
1gSE
Postby OkcSolarafreak » Thu May 05, 2011 10:50 am
i did the o2 before cat, the knock sensors are gotta have to wait.
Can't prove it!
OkcSolarafreak
Postby 1gSE » Thu May 05, 2011 10:57 am
Since you were under there replacing one sensor, you should have gotten the other one too. The sensor before the cat is the hardest of the 3 to replace. The knock sensor rewire will take like 10 minutes.
Solara-M62 @ 5.5psi
1gSE
Postby OkcSolarafreak » Thu May 05, 2011 11:00 am
im on a pretty limted budget lol and i work at autozone so every now and than stuff comes free and i got that an o2 for free. im not sure how to do the knock sensor rewire ive never had to do it before.
Can't prove it!
OkcSolarafreak
Postby 1gSE » Thu May 05, 2011 11:04 am
Solara-M62 @ 5.5psi
1gSE
Postby OkcSolarafreak » Thu May 05, 2011 11:12 am
thanks i appreciate it, im gonna go try that out real quick
Can't prove it!
OkcSolarafreak
Return to Toyota Solara OEM
