Do you reset ECU after alignment?
I was bored and browsing through TSB's.
Very interesting, makes sense. I've never had a car with VSC since I drive manual, so never had this issue. But it's good to know!
Dr J
March 25, 2008 T -SB-0020-08
Disconnect Battery & Perform Zero Point Calibration After Wheel Alignment Adjustment
The purpose of this TSB is to provide information on when and how to perform the zero point calibration on vehicles equipped with Vehicle Stability Control (VSC). Momentarily disconnecting the battery is a necessary step for performing the zero point calibration.
Dr J
- ThurzNite
- SolaraGuy Driver
