SolaraGuy.com • View topic - CEL light is on need some help please
Stock talk about Solara
Postby rg456 » Thu Oct 06, 2011 4:27 pm
hey guys well my 03 solara 2.4l got a cel the other day so I took it to autozone and the guy diagnosed it as a catalytic converter malfunctioin. He also said that sometimes it says that but it could be the 02 sensor or exhuast manifold leak or actually the catalytic converter. Could you all help me out with this is he really telling the truth it could be one of those three and if he is how could I figure out which one it is? Thanks in advance for your help.
rg456
Re: CEL light is on need some help please
Postby 1gSE » Fri Oct 07, 2011 4:27 am
whats the code?
Solara-M62 @ 5.5psi
1gSE
Postby chriscarter » Sun Oct 09, 2011 9:18 am
Very rare that a converter fails on its own except if it has been hit by something under the car. If the converter actually has failed, it was probably caused by another component causing an overly rich mixture. Check the code with another reader and go from there.
chriscarter
Postby rg456 » Fri Nov 04, 2011 5:57 pm
Ok guys sorry for taking so long to reply been busy at work but the cel code is P0420 the guy said cat stock up or bad o2 sensor is he right thanks in advance
rg456
Return to Toyota Solara OEM
