SolaraGuy.com • View topic - tail light indicator
Stock talk about Solara
Postby solara99white » Wed Nov 02, 2011 11:38 am
I have a tail light indicator that tells you need to changeyour tail light bulbs,I replaced all tail light bulbs and the indicator is stil on,what can I do to switch the indicator off?
1999 pearl white toyota solara se,6k white HID
solara99white
Re: tail light indicator
Postby ThatVietGuy » Wed Nov 02, 2011 12:23 pm
What about the third brake light?
ThatVietGuy
Postby solara99white » Wed Nov 02, 2011 4:53 pm
Which one would that be?
ill have to look into that
solara99white
Postby ThatVietGuy » Wed Nov 02, 2011 4:58 pm
The LED strip on the spoiler.
Or if you don't have a spoiler, the one mounted on the rear deck.
ThatVietGuy
Postby solara99white » Wed Nov 02, 2011 5:02 pm
Yeah I have a spoiler,but I recently had put that on...id say a year ago?
Maybe it just needs to be reset somehow?
solara99white
Postby ThatVietGuy » Wed Nov 02, 2011 5:49 pm
As far as I know, you don't reset the light like you would with, say, a check engine light.
Did you replace all the bulbs? Are you sure all the correct ones light up when you brake and when you turn the headlights on?
ThatVietGuy
Postby solara99white » Wed Nov 02, 2011 6:42 pm
Yeah parking lights go on,rear break and directionals seem to be good.I double checked to see if all the bulbs were in correctly
solara99white
Postby fastcherry » Wed Nov 02, 2011 8:49 pm
how do you replace the brake light on the spoiler??
fastcherry
Postby ThatVietGuy » Thu Nov 03, 2011 10:23 am
You need the whole light strip, IIRC.
ThatVietGuy
Postby solara99white » Fri Nov 04, 2011 5:55 am
Thanks for the input,it was the higher mounted stop light that was out. Quick and easy fix
solara99white
Return to Toyota Solara OEM
Users browsing this forum: Google [Bot] and 2 guests
