SolaraGuy.com • View topic - Bad Window Switch on passanger side help
Stock talk about Solara
Postby dhyfr » Tue Oct 30, 2012 6:54 am
It was just brought to my attention that my passenger side window doesn't roll up from the passenger side. It works as far as going down from that side and i can control it from the driver side roll it up and down. I am not sure if its the switch. It does seem slightly mushy when you press on it. Still has the click noise when you press or pull. Any one know what might be going on thanks. 04 solara
dhyfr
Re: Bad Window Switch on passanger side help
Postby GzNutz » Thu Nov 01, 2012 7:03 pm
You're going to have to pull the switch and put a voltmeter to it to see if its sending power when pulled in the up position.
Return to Toyota Solara OEM
Users browsing this forum: Google [Bot] and 2 guests
